Old 17th February 2009, 02:25 AM   #21
Default Photo of Three MLTLs
For comparison I have a photo of the 'Jordan with a Ribbon' MLTL, the Alpair 6 MLTL, and the Alpair 10 MLTL prototypes. the Jordan design was built a few years ago while the Alpairs are new ones as reported in this forum.
Jim
Old 17th February 2009, 08:14 AM   #22
how does the alpair 6 perform?
im very curious for them, still havent decided either alpair 6 or 5
Old 17th February 2009, 08:17 AM   #23
The Jordan's cabinet looks very very nice.
do u have any plan to combine the Alpair 10 Bass with Alpair 5 or 6 ?
Old 17th February 2009, 09:51 AM   #24
is it still possible to put alpair 5 and make the sealed enclosure for them without changin the dimension?
i try to make some drawings, i hope it can be clear
Old 17th February 2009, 02:44 PM   #25
Jim: Isnīt that port a bit small? Have you found out any port noise?
How much you think the changes of the driver height from the floor will affect the tonal balance of the finished speaker?
Nice work indeed anyway...
Cheers
-Mika
Old 17th February 2009, 02:44 PM   #26
For me the drivers seems to be too far away from each other then... But this is of course only my opinion then...
Old 17th February 2009, 02:48 PM   #27
the reason i did this, to have less effect on the T- Lines, which i can be wrong
other consideration since we need separate enclosure, its just for practical purposes to build the cabinet, which this partition create +- 1L
any suggestions are very well welcome
Old 17th February 2009, 02:51 PM   #28
rev 1 with outer dimension
Old 17th February 2009, 03:06 PM   #29
Thanks to all for the nice comments.
On Henry's drawing I'll agree that the two drivers need to be closer together for a better blend of the sound. Another idea would be to place the Alpair 6 (or maybe A5) in a open tube that on the back of the cabinet. It would be interesting as either a small sealed box or open back 'tweeter'. You have freedom on the crossover point between drivers to 'size' the enclosure for the A6 so that it would be less intrusive into the pipe for the A10.
One might choose to crossover high enough so that the baffle step compensation is achieved solely with the A10. This may also tend to reduce the volume needed for the A6.
On the port tube size: It is same diameter (2.06") as I used in my Jordan MLTL. I haven't heard any port noise from the recent A10 design nor from the Jordan design for years. I always check the port velocity during the design simulations. Not a worry in my mind.
Jim
Old 17th February 2009, 05:32 PM   #30
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default Re: Photo of Three MLTLs
nice looking speakers Jim
Originally posted by Jim Griffin
...... the Alpair 6 MLTL....
is that the same as presented by Scottmoose in this topic http://www.diyaudio.com/forums/showt...73#post1711973
edit: probably not, in scottmoose's design the driver is much more towards the top of the line
edit2: I should look at the new threads first, before asking it's here
Jordan JX92S from EAD or Mark Audio Alpair 10? ilwooz Full Range 56 20th March 2010 01:26 AM
Small MLTL for Mark Audio Alpair 6 Drivers Jim Griffin Full Range 25 16th July 2009 01:18 AM
Mark Audio Alpair 5/CSS SDX7 DIY Chris74 Swap Meet 4 17th February 2009 02:44 PM
Page generated in 0.09922 seconds (81.55% PHP - 18.45% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
