fe87e Superbowls
fe87e Superbowls
Old 28th January 2009, 07:05 PM   #11
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Originally posted by lejaybo
could a sub be built in a round enclouser ?
Sure, why not? It's actually pretty optimal for a subwoofer since there's only one side parellel to the driver so it's pretty easy to tame standing waves.
Old 28th January 2009, 07:14 PM   #12
lejaybo is offline lejaybo  United Kingdom
humm
interesting
i think a full round system would look pretty cool
two sats and a big sub
now to find a gaint wooden bowl lol
Old 28th January 2009, 07:21 PM   #13
kazoo is offline kazoo  United States
Juspur,
I have a question/suggestion. I like the idea of the wire being crimped from the speaker to the wire from the amp. I did notice the holes the wires passed through look open. Did you seal them? If not I would, using something like a 100% silicon or glue. Just a suggestion so they don't produce unwanted sound.
John
Old 28th January 2009, 08:17 PM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
fe87e Superbowls
Somewhere here is a Scandinavian build of a push-push woofer using the larger metal version of these bowls...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2009, 09:07 PM   #15
how would that sound?
i was thinnking...
could a use tube with a sub at the bottom
and one of these fix on top ??
Old 28th January 2009, 09:10 PM   #16
Hugo82 is offline Hugo82  Netherlands
B&W has a round subwoofer enclosure.
Old 28th January 2009, 09:34 PM   #17
pimp sub
me likey, any clues where i could get a big wooden ball?
could i setup a push pull setup in a simple tube?
Old 29th January 2009, 06:11 AM   #18
Juspur is offline Juspur  Denmark
Hi Kazoo
Yes, I sealed the holes for the driver-wires with silicone. No unwanted noises
Old 4th February 2009, 07:07 PM   #19
i want to use a subwoofer with a pair of these superbowls but do you have any clues frequency my sub needs to come in at
Old 4th February 2009, 07:22 PM   #20
Well, it depends on the order of the sub-crossover:
If it's a 12 db/octave, I would suggest it to begin rolloff around 120 Hz,
If it's a 24 db/octave, I would suggest it to rolloff from 150 Hz.
Please remember to make a crossover that also protects the superbowls - otherwise they'll be damaged at moderate to high volume, due too large movements.
fe87e SuperbowlsHide this!Advertise here!
Fostex FE87E horns on Ebay sharpi31 Swap Meet 0 7th January 2007 11:07 AM
fe87e recommended back horn... blumenco Full Range 1 26th July 2006 07:48 AM
'off the shelf' FE87E BLH bibster Full Range 3 16th June 2006 07:06 AM
Fostex fe87e or TB W3871s ? type Full Range 1 1st April 2006 08:13 AM
FE87E Graphs philipbarrett Full Range 3 22nd November 2005 10:03 PM
