Old 27th January 2009, 10:10 AM   #1
OzMikeH is offline OzMikeH  Australia
Default Looking for a horn design for my drivers.
No not really. I just wanted to waste some of HM's time like
he wastes mine by plugging his designs in any remotely compatible thread, then doesn't contribute any useful advice unless directly related to his design.
HM is probably a nice guy but please, SO predictable... Please do not be so pushy with promoting your products sir.
Sponsor this site and get an advertisement at the bottom of the page. You'll get more business than now, It reminds me of the Microsoft word Paperclip.
Help some guys with funny hair bang two rocks together really hard.
http://athome.web.cern.ch/athome/LHCathome/whatis.html
Old 27th January 2009, 01:51 PM   #2
Hi OzMikeH,
Sorry for being OT here, but how did it work out with your FE207E that had the crushed whizzer? Did you find a good ribbon as planned? I'm curious where you crossed over.
Old 27th January 2009, 03:22 PM   #3
Really; no one else ever plugs their designs or driver mods or anything...
Has anyone tried building HM's designs?
I just hear so much bashing...
Always liked the looks of the one that looks kinda like a Fletcher system, but open in front.
And I've always wondered how those dual blh systems would work, tuned slightly apart to spread the FR...
Never built one though.
Old 27th January 2009, 03:51 PM   #4
GM is offline GM  United States
GM's Avatar
I've periodically recommended tuning vented alignments individually to better blend in-room, so doing it with the much higher 'vent' gain BLHs seems a 'no-brainer' to me.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th January 2009, 06:41 PM   #5
yes, agreed.
but i've never actually built one.
'specially w/ dual "vents" tuned to two freqs.
doubt i ever will...
will try a nessie pipe, tuned to the little room it's going in tho...
Old 27th January 2009, 07:11 PM   #6
GM's Avatar
If you use two vents to tune a common Vb, then you get an averaged out Fb that basically demands a little lower tuning to get the desired Fb since the shorter vent dominates.
GM
Old 27th January 2009, 10:15 PM   #7
in the nessie?
i hadn't even looked @ them that close yet (measured anything), but they look like they're an octave apart.
Old 27th January 2009, 10:33 PM   #8
GM's Avatar
Don't know what a 'nessie' is, but I do know about staggered vents in a common Vb, at least typical PVC or cardboard tube ones and if you spread them too far apart tuning wise, the short one will dominate same as mis-matched drivers in a common Vb where the higher Fs one will provide almost all the output until it grenades. This is why in prosound apps they tend to either use push-pull layouts to average out non-linearities and/or separately tuned cabs for each driver.
GM
Old 27th January 2009, 10:50 PM   #9
Scottmoose's Avatar
Here be monsters...
The Nessie's were one of Nagaoka's specials (although I imagine someone else had done something similar before, given that there's not much new under the sun). Twin constant cross-section resonant tubes basically, the longer rear one larger than the front.
Old 27th January 2009, 11:19 PM   #10
GM's Avatar
OK, thanks! So is the small one being used to hammer down a nasty peak like TD apparently uses in his DTS-20?
GM
Horn or BVR design help for 3" TB or Peerless drivers BoilermakerFan Full Range 15 21st January 2008 07:54 PM
Dual drivers in 1 horn. lbg Full Range 23 3rd January 2008 12:23 AM
Horn sub. wich drivers?? wuffer Subwoofers 4 28th July 2007 04:01 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 11:44 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 2nd August 2004 12:33 AM
Page generated in 0.10894 seconds (75.66% PHP - 24.34% MySQL) with 11 queries
