Extreme BIB cabinet EnABL
Old 18th February 2013, 06:47 PM   #121
B00B00 is offline B00B00  Canada
B00B00's Avatar
Seeing as I will be coating the entire interior surface of the speaker I picked up some acrylic floor wax. (The small bottles weren't going to cut it) A quick spray of polyurethane in a can... (the plaster rectangles might not take to kindly to being slathered in floor polish.) and we should be off to the races. This is the same stuff made by Johnson that the guys use on the model airplane forums. Click the image to open in full size.
Have started assembling...
Old 22nd February 2013, 02:40 AM   #122
Alex from Oz is offline Alex from Oz  Australia
Alex from Oz's Avatar
Hey Bud,
Is this stuff the same as the micro gloss?
http://www.buxnie.com/images/Product/large/238568.jpg
Alex
Old 22nd February 2013, 05:50 AM   #123
BudP is offline BudP  United States
BudP's Avatar
Honestly, I don't know Alex.
Many years ago ,when I contacted Micro Scale about buying quantities they indicated that the Gloss was an industrial strength acrylic floor wax, that they purchased in 55 gallon drums. I did not ask who made it at the time.
They are more closed mouth about it now. There has been a change in chemistry, about 10 years ago. I still have some of the earlier material and of course some of the current also. When I used a lot of the material, the earlier product sounded slightly better and seemed physically more flexible.
To find out, all you really need are a pair of silk dome tweeters, as cheap as possible.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 22nd February 2013, 08:03 AM   #124
Thanks Bud.
Alex
Old 24th February 2013, 02:23 AM   #125
Carlp is offline Carlp  United States
Bud
Can you elaborate, Bud?
Old 24th February 2013, 04:28 AM   #126
BudP's Avatar
Silk dome tweeters are very susceptible to EnABL and Micro Gloss. A stiffer material will raise output and may introduce obvious FR peaks. A softer material does less damage.. So, if the material under question matches the Micro Scale Gloss in performance change, then it is for all intents the same material. Easier and cheaper than messing with wider range drivers.
Bud
Old 11th March 2013, 01:25 PM   #127
B00B00's Avatar
Hi Bud and Alex, just to say that the cabs are up and running...
In a word, *very* articulate... lots of low level information on recordings that I have never picked up before.
I posted pics here:
http://www.diyaudio.com/forums/full-...ml#post3405743
But this gives you a general idea of what the cab looked like before being sealed up.
I will post listening impressions later.
Thank you for all of your sage advice.
Next on the list of things to do, enable the speaker and then the outer baffle.
Looking forward to what further tweaking will bring.
-andré-
Old 11th March 2013, 01:45 PM   #128
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Andre,
Congratulations on being up and running! Wish I could hear them. Do you have a Zoom recorder to post mp3 clip of your speaker in action?
Btw, are you using stuffing inside or leaving it just with the Enable treatment? Seems like stuffing, it touching the treatment would render it useless.
X
Old 11th March 2013, 07:59 PM   #129
G'day andré,
Great work. Love the photo's!
The treatment on the outside will really bring it all together.
Looking forward to your listening impressions.
Alex
Old 12th March 2013, 04:19 PM   #130
B00B00's Avatar
Unfortunately I don't have a zoom recorder, I could record it with my camera but the mic is nowhere near as good. Listening impressions are posted over in the regular thread here:http://www.diyaudio.com/forums/full-...books-523.html
-andre-
Extreme BIB cabinet EnABLHide this!Advertise here!
Guidelines for cabinet extreme proportions? Brisso57 Full Range 6 24th June 2009 03:19 AM
HEATSINK extreme cumbb Pass Labs 4 17th May 2006 02:14 AM
Extreme thin (depth) cabinet for FE83E siuguyguy Full Range 5 9th September 2005 07:14 PM
Extreme DAC 3.0 martioz Digital Source 3 11th March 2003 10:45 PM
Really, really extreme phono, more extreme than mine peranders Analogue Source 34 22nd October 2002 11:59 PM
