Best solution to missing B200 bottom end
Old 27th January 2009, 11:40 AM   #21
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
True enough, plus the AC OB forum that inspired it: http://www.audiocircle.com/circles/index.php?board=90.0
The Dark Star thread in particular is a plentiful resource for B200s on OBs.
Old 27th January 2009, 11:51 AM   #22
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I am still playing with open baffles. I just put in a pair of Alpha 15a's, and amconsidering using two per channel.
Something different to consider for the lower end.
T-Bass circuit
http://www.diyaudio.com/forums/showt...25#post1622325
Also, some more open baffle ideas at -
www.quarter-wave.com
I am considering the lowther + 2 Alpha approach. (just dont have x-overs in hand)
I am starting to think an L-PAD is a must for getting bass occasionally balaned out in comparison to full range.
Mike
Old 27th January 2009, 12:03 PM   #23
Piek is offline Piek  Europe
Piek's Avatar
Also see in this context (large baffles), another interesting point of Rudolf: http://www.audiocircle.com/circles/i...?topic=64048.0
-Micha
Old 27th January 2009, 12:12 PM   #24
S.Spielbergo is offline S.Spielbergo  United States
Dave, are your efficiency ratings an average or from say 600hz -18khz? Stock units? How much of a drop in response did you see towards the bottom octaves when measured in your baffles? I'm running a T-amp so I'm trying to hang on to every db I can.
Old 27th January 2009, 11:35 PM   #25
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Efficiency is waht is spit out by the T/S calculator on stock units. You lose a bit less than a 0.5 dB when treated (but gain at least 10-15 dB downward dynamic range at the bottom).
The only efficiency that counts is the lowest efficiency in the bandwidth you are using them. I'd be happy with a nice 10ish watt PP with B200. Our 4 w SE or PP amps weren't quite enuff.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2009, 01:42 AM   #26
After some experiments I've decided to give the line level filter a chance. I'm honestly not too crazy about cutting any more holes in these baffles plus if I don't like the filter I can just disconnect it and toss it in the pile with the rest of my aborted electronic crap. I'm going to see about a filter that will only augment the top end 3db rather than 6db, these guys are pretty good they just need a little help.
Old 28th January 2009, 05:00 PM   #27
konut is offline konut  United States
Very interested in your findings. You might want to skim this thread for, what might be, useful info.
http://www.audiocircle.com/circles/i...seen#msg280444
I'm using passive power level compensation circuits and find they impose too much of a sonic signature. Line level is an interesting, and potentially less onerous, alternative. Please keep us informed, thanks
"If we knew what it was we were doing, it would not be called research, would it?" A. Einstein
Old 29th January 2009, 02:15 AM   #28
I will be ordering some parts from digakey tonight, we'll see how it goes once they come in.
Old 29th January 2009, 10:26 AM   #29
hm is offline hm  Europe
hm's Avatar
Default S.Spielbergo
late, but i wonder that noone will
take a SAT horn solution with the B200,
no crossover down to ~100 Hz with ~96-98 dB
look my sats TRUMPET, SCHALMEI, HORN
with measurements and plans:
http://www.hm-moreart.de
Old 29th January 2009, 10:45 AM   #30
hornophile is offline hornophile  Europe
Hello,
1.
How do you integrate with the sub around 100 hertz ?
Is there a need for a crossover ?
2.
What's the best or the acceptable solution for the bass module ,
A woofer in bassreflex enclosure with plate amp ?
A basshorn ?
Thanks !
Best solution to missing B200 bottom endHide this!Advertise here!
No Bottom E? TubeHead Johnny Multi-Way 82 2nd December 2008 03:08 PM
The 'bottom end' PeteMcK Everything Else 0 18th September 2008 08:18 AM
Venting sub out bottom... Godzilla Subwoofers 0 5th August 2008 11:55 PM
Best way to connect top to bottom minh_827 Multi-Way 6 6th September 2005 06:40 AM
Copyright ©1999-2017 diyAudio
