Old 25th January 2009, 08:54 PM   #21
Originally posted by GM
WRT MLTLs, I simmed these for a local awhile back, but he went MIA on me, so don't have a clue if either was built. .......(snip).....
Anyway, if you build either I'd appreciate some feedback:
GM
GM-
Thanks for your (many) posts which I've been reading here as I skulk about in the shadows...
I have a pair of AN10s (now residing in the 2.8II AN cabs) and a pair of AN12s as well (those sitting on the shelf).
If you could run those drivers through the same MLTL sim you did (above) for the AN8s, I will build (at least one, if not both of ) them and let you know the results. I'm reasonably happy with my AN10s as-is, but I'm looking for something 'better' for them. I picked up the AN12s on impulse, hoping that I could get decent bass without messing with subwoofer and such.
John
Old 26th January 2009, 01:34 AM   #22
I built blh for my nirvanas. Design was for PHY but it seems to work well with AN´s too. These sound great with good recordings and tube amps. However my friend who is more into heavier music uses The notch filter of 206 solo and this makes for a great allrouder.
Here shown in testing.
Old 26th January 2009, 02:21 AM   #23
GM is offline GM  United States
GM's Avatar
Originally posted by VictoriaGuy
GM-
Thanks for your (many) posts......
I have a pair of AN10s......
If you could run those drivers through the same MLTL sim you did (above)......
You're welcome!
Which model?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th January 2009, 03:58 AM   #24
freddi is offline freddi  United States
freddi's Avatar
AN10 - don't seem like a rocker - has plenty of top end
in big Karlson -- excursion is reduced even compared to tuning the reflex higher
http://img296.imageshack.us/img296/7831/an10k15xg2.jpg
Z -- K15 with 30.5 sq.in. vent
http://img296.imageshack.us/img296/4...tan10z1ts3.gif
K vs reflex (tuned around 41 = "too low" imo)-
http://img235.imageshack.us/img235/4...an10ir1sg8.gif
sim BS half-horn
http://img242.imageshack.us/img242/2...1096lhhex3.gif
sim short BIB (if theres such a thing
http://img292.imageshack.us/img292/7...220lbibmc3.gif
An10 off floor vs BK20 with Sammi and ST324
http://img80.imageshack.us/img80/649...4vsan10hq4.gif
terrible place to tune AN10 in 70 liter reflex
http://img237.imageshack.us/img237/1...wt3ploteo0.gif
Old 26th January 2009, 04:26 AM   #25
You're welcome!
Which model?
GM
GM-
I have AN10 'Super' and AN12 'Super' ie- 'Ordinary' , not cast frame models.
John
Old 26th January 2009, 05:09 PM   #26
GM's Avatar
Audio Nirvana Super 10:
Vb = Vas, Fb = Fs MLTL:
L = 57.25"
WxD (CSA) = ~108.804"^2
zdriver = 20.687"
zport = 54.25"
dport = 4"
Lport = 3"
Vb = Vas, Fb = Fs MLTL (short):
L = 46.75"
WxD (CSA) = ~133.227"^2
zdriver = 10"
zport = 43.75"
dport = 4"
Lport = 4"
Audio Nirvana Super 12:
L = 61.1"
WxD (CSA) = ~291.03"^2
zdriver = 24.6"
zport = 58.6"
dport = 5"
Lport = 1"
L = 46.75"
WxD (CSA) = ~380.405"^2
zdriver = 10"
zport = 43.25"
dport = 5"
Lport = 2"
All dims inside (i.d.) and approximate, 0.2 lbs/ft^3 polyfil stuffing density simmed.
GM
Old 26th January 2009, 06:05 PM   #27
freddi's Avatar
hey GM - -here's a quick hand-held TS for stamped frame Super 10 - -tried to hold it steady and away from my body - -not sure good this is but might be ballpark - - if so then qts is higher than spec (?) can one get good TS in an 8x10x8 room?
Old 26th January 2009, 06:56 PM   #28
@GM: can you give me a resource to quickly understand how to make a project out of the specs you gave me?
@nelson pass: do you mean that the bigger models (10-12") are performing well alone in a OB?
@freddi: "AN10 - don't seem like a rocker - has plenty of top end". too much top end making it unsuitable for rock?
can anyone give me a starting point (thread/link/project) for a costeffective sub that wuold match the super 8" on openbaffle?
and also a starting point about building an amp to biamp the woofers?
i know i'm going off-topic a bit, but i would like to make some fast idea about which solution i can afford. my current setup really doesn't work. that is i'm living without music most of the time.
Old 26th January 2009, 07:07 PM   #29
freddi's Avatar
regarding AN10's top end - its very good - an issue might be balancing when listening almost on-axis such as the aggressive filter seen on this page (which might be overkill?) - - its best to ask other users
http://www.audiodesignguide.com/Nirvana/index2.html
Old 26th January 2009, 09:20 PM   #30
GM:
Thanks for the sims for the AN 10 and 12.
I'll get one (or both) of these built later this spring, and I'll let you know how they work out.
Thanks again!
Cheers
John
Audio Nirvana Drivers drwho Full Range 15 20th December 2007 05:33 PM
box for 6.5" audio nirvana ranaya Full Range 6 11th September 2007 02:31 AM
Audio Nirvana autheim Multi-Way 6 21st November 2006 11:46 PM
Audio Nirvana - Where Is It? How Do We Get There? Bas Horneman Everything Else 9 25th January 2006 02:05 AM
Page generated in 0.10879 seconds (84.56% PHP - 15.44% MySQL) with 11 queries
