Old 22nd January 2009, 03:15 PM   #11
badman is offline badman  United States
Custom Title
badman's Avatar
A FF225k with a fostex ft17h in a BIB would fall in budget and really perform spectacularly. The ft17H is NOT a tweeter, it's a supertweeter, and people trying to use it as a tweeter have branded it 'spitty'. One would want to use a tiny little cap on the ft17h (1uf) with the 225k run full range. With the appropriate input power limitations, it's a fantastic little supertweeter.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 22nd January 2009, 04:25 PM   #12
chrisb is offline chrisb  Canada
Another approach could be something like an FE207/FF85K combo - XO between 200-300Hz. This 3" driver is not only cheaper than the FT17H or any of Fostex's dome tweeters, but it's quite an amazing little wide-bander - certainly not lacking for detail from the upper midrange to beyond the extent of my hearing (now probably less than 15KHz) .
Mind you, the direction in which the sensitivity is mismatched by over 6dB (ie. less for the 85K) makes for more awkward passive balancing, or biamping, either of which could stretch a budget too far.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 22nd January 2009, 04:36 PM   #13
Godzilla's Avatar
>>> A FF225k with a fostex ft17h in a BIB...
Without having heard this combination i salivate at the thought! This may be the ultimate BIB! Except of course the one using the Eminence 12LTA 12" wide range driver (which may provide more output than any other BIB)... But the quality of sound from the 225k + ft17h should be superb. I'd build this if i had an appropriate room.
Godzilla
Old 22nd January 2009, 06:38 PM   #14
chops is offline chops  United States
chops's Avatar
Default Re: Re: Re: Re: which fostex for $250?
Originally posted by rkevans
You're right. I think we need to arrange some sort of a show-and-tell meeting this spring for the locals.
Rick
That would be neat. I wouldn't want to show up with cardboard speakers though. Then again, the way they sound... LOL
Also, TheTubeGuy1954 is also in your area.
Charles
Old 23rd January 2009, 12:19 PM   #15
Default Re: Re: Re: Re: Re: which fostex for $250?
why not???
if they sound good i'd do it; that's part of the fun!
the last couple "bring your own" audio get togethers i went to, i brought something "funny looking," not even close to what the forums said would work, etc.
by the end of the night they got the most listening time, by far.
and the "jaw drop" factor is just fun too...
Old 23rd January 2009, 06:30 PM   #16
Thanks for the great suggestions folks! I've made the plunge, and ordered a pair of FE166's from solen.ca , so I can go up in size. I want to keep it strictly a one-driver-per-speaker design, so I didn't go for the FF's.
Thanks again. I'll post results in the BIB or pics thread :-)
Mitch
Old 24th January 2009, 01:01 AM   #17
chops's Avatar
Default Re: Re: Re: Re: Re: Re: which fostex for $250?
Originally posted by serenechaos
why not???
True. Who knows, I just might if they're still in cardboard boxes by then, but I hope not.
Charles
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 06:00 PM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 01:35 PM
Fostex BLH boonedog Full Range 1 23rd March 2005 08:39 PM
Fostex FE 206 E in ML TL Again levon Full Range 0 16th April 2004 08:02 AM
Page generated in 0.10175 seconds (75.63% PHP - 24.37% MySQL) with 10 queries
