#11 | |
frugal-phile(tm)
note that the shifting of the parameters will also be affected by the weather. As to the laterel brace, the one parallel to the baffle, i'd loose it as Chris suggests. A brace should always be edge on to the driver. Further this points out something you are giving up by going to multiple round ports... the slot ports on the side, by their very construction, create an incredibly stiff box panel, they are inherntly self braced. As well choice of the speacer used can further enhance this. We use a dissimilar material, most often MDF, to further isolate the outer wall from the inner wall, the different impedance of each layer of material -- one of the reasons for using plywood (9 layers in 12mm, 11 lauers in 15mm, 13 layers in 18mm BB) is that at each layer inteface, you get an impedance change and therefore any vibration is dissipated/damped. In other words with the Onken-style ports the lateral brace is unnecessary. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 | |
frugal-phile(tm)
dave
#13 | |
frugal-phile(tm)
dave
| Page generated in 0.07852 seconds (73.14% PHP - 26.86% MySQL) with 10 queries |
