Old 20th January 2009, 05:24 PM   #11
frugal-phile(tm)
planet10's Avatar
Should be mounted on the wall... there should be more bass if not more extension.
Ceratinly you would have no problems with baffle step.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th January 2009, 05:26 PM   #12
HK26147 is offline HK26147  United States
In my case, that's my impression; it performs like a monopole
Old 20th January 2009, 07:06 PM   #13
Bigun is offline Bigun  Canada
Bigun's Avatar
This is getting more and more encouraging.
Keeping a consistent design between an HT centre channel and surrounds has an appeal because then there is only one design to make. A higher aspect ratio would be more flexible, with a central location for the driver.
If this were the preferred approach (I have to give these restrictions some thought) then the options might be more limited in terms of how a Fonken is implemented. One option is to take the Fonken-tuned floorstander and move the driver to the mid point and stick it on the wall vertical or horizontal (port to exit at the end rather than out the back). One could put a port at both ends if this had some advantage?
Another thought, perhaps getting carried away now, is to fold the port inside the enclosure so that port length was maintained ?
p.s. I found a website where somebody made an interesting wall-mounted flat spiral horn using a Fostex. I have no plans for one of these but thought you guys would be interested.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 20th January 2009, 07:07 PM   #14
Bigun's Avatar
ah, didn't know attachments are limited to 1 per post, here's my doodle on the 'folded port'
Old 20th January 2009, 07:30 PM   #15
frugal-phile(tm)
planet10's Avatar
I wouldn't put it exactly at the midpoint, but that would actually (i'm guessing) improve the sonics.
I did sketch a version with the port out the top, but chose not to go that way as things tend to find their way inside the box.
dave
Mounting speakers behind a wall brox Full Range 0 13th November 2007 08:53 PM
So, why not in-wall speakers? wigginjs Multi-Way 4 20th August 2007 02:59 AM
In wall custom speakers CPopowski Multi-Way 4 19th March 2007 11:16 AM
In-wall recessed speakers Magnetmaz Multi-Way 1 4th June 2003 03:53 AM
In wall speakers bostarob Multi-Way 11 23rd June 2002 06:12 AM
Page generated in 0.09318 seconds (65.51% PHP - 34.49% MySQL) with 11 queries
