Old 19th January 2009, 03:21 AM   #11
mp9 is offline mp9
haven't given it much thought. maybe use the front panel/baffle as nothing more than a dust cover. i would need to find a good driver(s). then the question of how far away from the org. design to go or will it ever have antique value as is? don't know if i'll ever get around to it.
Old 20th January 2009, 06:48 PM   #12
mp9 is offline mp9
Default just found these 8Ω 6x9's in another forum-
http://estore.websitepros.com/1203052/Detail.bok?no=4
93db 4Ω so i assume the 8Ω version is 90db. hard to tell with the grill on but looks to be fullrange/wizzer, would be interesting to see t.s. specs and plots. i'm going to add them to my fleabay saved search option.
Old 20th January 2009, 11:09 PM   #13
Just been in another part of this forum where there is a discussion regarding the use of curved enclousures in modern loudspeakers. It's an eye opener to see that this technique has been captured in such an old loudspeaker.
Old 20th January 2009, 11:16 PM   #14
BTW. You could improve the sound quality by adding dampening to the cabinet walls, better acoustic dampening. Block off the port. Finally, install a passive equaliser (~2MH/2uF) in series to achieve as flat a response as possible.
Grundig TK 46 manual TaaiGwokJan Tubes / Valves 7 8th October 2010 09:32 PM
Grundig TK-46 manual little-O Analogue Source 0 28th November 2008 04:24 AM
Grundig CD303, anyone know it? tubenut Digital Source 0 30th May 2008 06:33 PM
Grundig oscilloscope typ 51 sparkle Equipment & Tools 0 11th February 2008 09:07 AM
Grundig is better than PassLabs, there's no matter! kyrochan Everything Else 25 4th June 2007 03:07 PM
Page generated in 0.08464 seconds (65.56% PHP - 34.44% MySQL) with 10 queries
