Old 15th January 2009, 05:21 AM   #1
chylld is offline chylld  Australia
Send a message via ICQ to chylld Send a message via MSN to chylld
Default HiVi B3s voice coil inductance - How to calculate?
I'm trying to figure out a zobel network for my hivi b3s system, and for that I need to know the inductance of the b3s voice coil. I have lots of T/S parameters (below) but no mention of Le/Lvc
Nominal Impedance (Z)(ohms) : 8
Resonance Frequency (Fs)(Hz) : 80
Nominal Power Handling (Pnom)(W) : 15
Sensitivity (2.83v/1m)(dB) : 82
Weight (M)(Kg) : 0.53
VC Diameter (mm) : 20 CCAW
DC (Re)(ohms) : 6.5
VC Length (H)(mm) : 9
VC Former : Kapton
VC Layers : 2
Magnet System : Shielded Ferrite
Force Factor (BL)(N/A) : 2.9
Gap Height (He)(mm) : 3.0
Linear Excursion (Xmax)(mm) : 3.0
Suspension Compliance (Cms)(uM/N) : 1260
Mechanical Q (Qms) : 4.29
Electrical Q (Qes) : 1.19
Total Q (Qts) : 0.93
Moving Mass (Mms)(g) : 3.1
Effective Piston Area (Sd)(m2) : 0.0030
Equivalent Air Volume (Vas)(L) : 1.6
Cabinet Type : Sealed
Recommended Box Volume(Vb)(L) : 2
-3dB Cut-Off Frequency(F3)(Hz) : 80
I can't find anything in the manufacturer's documentation either.
Is there any way to calculate the inductance using the parameters above? Or must I buy an LCR meter?
Old 15th January 2009, 02:20 PM   #2
squib is offline squib  United States
squib's Avatar
Default Zaph lists as 0.43 mH
Zaph lists the coil inductance as 0.43 mH. see here: http://www.zaphaudio.com/smalltest/compare.html
Note, you'll have to select the correct driver to see the T/S parameters.
Old 15th January 2009, 08:10 PM   #3
Default Re: Zaph lists as 0.43 mH
awesome, thanks!
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 07:36 AM
FE127E voice coil inductance for Zobel calculation arjscott Full Range 3 7th February 2007 02:42 AM
Measuring voice-coil self-inductance Klimon Multi-Way 4 19th November 2006 01:23 PM
voice coil inductance VS transient response kan3 Multi-Way 12 9th February 2004 09:18 PM
Voice Coil Inductance (Le) and Transient Responce amo Multi-Way 11 8th June 2003 08:45 AM
Page generated in 0.09573 seconds (73.39% PHP - 26.61% MySQL) with 10 queries
