Old 12th January 2009, 11:37 PM   #1
chylld is offline chylld  Australia
Send a message via ICQ to chylld Send a message via MSN to chylld
Default My first DIY: Cyburgs Needles with HiVi B3S
Thought I'd share my first DIY speaker project. Chose the needles since they're quite easy to build, although the tricky part was getting perfectly straight edges and trying to make do with only 6 clamps Nonetheless they came together quite well!
Here's a pic of them in my study:
and just before the drivers went in (I originally put 4x too much stuffing, getting it out and putting the correct amount in through the 70mm hole was quite a challenge!) :
I followed the standard needle design, except with the front and back thickened to 16mm and a HiVi B3S driver rather than the TB which I couldn't source here in Australia. The front side and top edges have been rounded off with a 9.7mm radius bit. Cabinet hasn't been painted yet as I want to match the driver well, which hasn't yet been decided (see below.)
Because the door is to the left of the table, I have to live with an off-centre arrangement for now, but I don't seem to be getting any bad corner effects or anything. Soundstage is much bigger with the speakers aiming straight forward, although the sweet spot is much wider when the speakers are aimed more inward.
Overall the sound is quite impressive, if not a bit bright and slightly tinny. The 8kHz breakup node was handled by (the second half of) Zaph's B3S filter, without which some songs are almost painful to listen to. The needles reach down to about 100-something Hz but very quickly fall off and require the help of a sub (you can see my 12" unit in the corner.) I suspect other more suitable drivers (TB W3-871S, Mark Audio Alpair6) will have more bass.
The only speakers I can compare these to are my previous stereo pair of LSK M5's. The needles are hugely more ambient and much less fatiguing to listen to, and surprisingly blend much better with my 12" sub (the M5's exhibit a bit of a mid-bass black hole by comparison.) Even more surprisingly, the needles seem to handle hard rock better, although admittedly it does get quite muddy.
I'd like some opinions on my next step. I'm pretty sure I can eek some better sound quality by using more appropriate drivers (TB or MA) but can anyone help set my expectations for improvement with the needles? If the needles are inherently treble-happy, would I be better off building another pair of totally different speakers?
Happy to hear all comments/suggestions!
Old 13th January 2009, 03:30 AM   #2
ttan98 is offline ttan98  Australia
You can buy Tangband Bamboo 1320 from Ebay:
Try, http://stores.ebay.com/AudioTek-Shop...QQftidZ2QQtZkm
The last bid price sold on the Bamboo 1320, per pair incl delivery is US$64
Old 13th January 2009, 03:34 AM   #3
Is that a drop-in replacement for the W3-871S? (1320 appears to be 4")?
Old 13th January 2009, 03:56 AM   #4
871 is 3" and 1320 is 4" don't think they are direct replacement even you cut a larger hole.
I tried the 871 in open baffle I was not impress, in needle cabinet maybe ok because many people reported good results.
try contact timn8ter, http://www.diyaudio.com/forums/membe...o&userid=7563,
he may have a few left, I bought mine from him.
Old 13th January 2009, 10:26 PM   #5
I think he ran out, contacted him already. My sights have since been set on the alpair6, as this graph (courtesy of Henkjan in the main needle thread) shows:
from top to bottom, they are:
1) alpair6
2) bb3.01
3) w3-871
4) w3-1285 / hivi b3s
Old 13th January 2009, 11:02 PM   #6
Scottmoose's Avatar
Or alternatively, as I suggested for someone via a PM discussion WRT a box for the Alpair6, a simple MLTL should provide more gain & somewhat less ripple (baffle-step aside, which also applies to the Needle)
30in x 6in x 4.25in, Zd = 2.5in, Zp = 29in, vent 2in diameter x 4in long. Line top, back & one sidewall with 1/2in wool felt, stiff fiberglass or similar.
YMMV of course. Just a thought.
Old 13th January 2009, 11:23 PM   #7
Thanks scott! that response curve makes the needle seem a bit unrefined to say the least.
Forgive my noobness, but would you be able to point out what the Zd and Zp are? My guess is that the Zd is the width of the thin end of the line (making the thick end 3.5in, discounting barrier thickness and assuming your 30x6x4.25 dimensions are internal) and that Zp is the distance from the centre of the port to the bend in the line, i.e. 1in from the thin end and thus right up against the end of the line?
Old 14th January 2009, 12:07 AM   #8
Scottmoose's Avatar
You're welcome.
Zd = Zdriver. The distance of the driver-centre from the throat / sealed end of the line / whatever you want to call it.
Zp = Zport. The distance of the port-centre from the throat / sealed end of the line / whatever you want to call it.
No bends, no taper, no internal panels. It's a straight, unfolded, mass-loaded QW line, i.e. an MLTL. So you have a simple, rectangular cabinet with internal HxWxD dimensions of 30in x 4.25in x 6in (you can swap the WxD dimension if you feel so inclined), with the driver-centre 2.5in down from the top, & the cylindrical vent 1in up from the bottom. The top, back & one side-wall of the cabinet lined as described above. Note that this was for the Alpair6 -other drivers will give of their best in cabinets designed for them.
FYI, the Needle is technically a mass-loaded horn. if a line expands toward the terminus, it's a horn.
Old 14th January 2009, 12:15 AM   #9
Thanks for the explanation; so this would be one of those QW designs that less knowledgeable people call bass reflex boxes? (I read the whole thor clarity thread yesterday, I'm quite aware of where you and dave stand on that subject )
It makes sense that the needle is a horn. I was explaining to friends on the weekend that I had just built "a mass-loaded, tapered, quarter-wavelength tube" and I just got blank looks. Horn sounds nicer. (And mass loading simply means that the port is significantly smaller than the line's end cross section, at which the port is positioned?)
Is it OK to position the driver in the middle of the baffle, or should I offset it?
I appreciate you letting me ask this many questions
Old 14th January 2009, 12:35 AM   #10
Scottmoose's Avatar
A Bass Reflex enclosure by definition utilises Helmholtz resonance, and assumes a uniform air particle density within the enclosure, with no standing waves. An MLTL deliberately generates and uses standing waves; it's primary resonance action is QW, not Helmholtz.
Actually, a TQWT historically was the exact opposite of what is generally described as a TQWT today. Originally, TQWT refered to a cabinet that narrowed toward the terminus, not one that expanded. Such cabinets are inherently mass-loaded, due to their negative taper. Almost nobody uses the term in that sense these days, but I thought a bit of history might be of interest.
Right -as I noted above, technically, if a cabinet expands toward the terminus, then it's a horn, and if the terminus is then choked / restricted, then it's a mass-loaded horn. Doesn't really matter all that much & arguably we're in the realms of semantics as they're all variations on resonant behaviour, but IMO, the definitions do have uses on occasion, like when you're examining the harmonic behaviour of different types of line.
Re horizontal offset of the driver, there wouldn't be room if you went with the narrow / deep option to do much, so personally, I wouldn't bother. You could if you felt so inclined with the wide / shallow option, but TBH, again, I probably wouldn't worry about it all that much. You're unlikely to hear a difference.
Cyburgs-Needle and Cyburgs-Pipe for FRS 8 Cyburgs Multi-Way 20 2nd October 2007 09:24 PM
can i use needles? ACQUA Full Range 3 23rd October 2006 03:22 PM
Any Aura NS3 plans like the Cyburgs-Needles? mazeroth Full Range 2 19th May 2006 02:40 AM
Linus 2 vs needles ? Branwell Multi-Way 0 4th October 2003 02:36 AM
Page generated in 0.15112 seconds (88.27% PHP - 11.73% MySQL) with 11 queries
