#21 |
Jamesuk1,
Not sure if you are still interested in EnABLing your Chilli Chang cabinets? An alternative (easier and quicker) way to apply the blocks is on a strip of 18 mm Scotch brand 'Magic tape' or Sellotape 'Invisibe Tape'. Once you have your blocks cut, lay a strip of Scotch tape sticky side down on the cutting mat and then lay the blocks on top as shown in the attached pic. The dotted line is the middle of the strip. The longer strip is for the back wall and the shorter one for the horizontal part. So you will need to make up four (4) of each strip to do both speakers - which equates to 152 blocks in total. So long as the edge of the blocks is positioned as shown in my earlier post it will work as intended. I have been applying EnABL to cabinets, baffles and ports for over 12 months (hundreds of blocks). Once you hear the change for yourself, you will want to EnABL everything. Cheers, Alex |
#22 |
Hi Alex,first i want to thank you so much for taking the time to explain Enabling to me.To be honest im not too keen on spoiling the looks of my speakers,having not long built them.Im realy keen on fullrange speakers and will continue to follow all the posts on enable etc.I still may try it in the future.I thank you again
James |
#23 |
Nothing really to spoil the looks of your speakers given the positioning of the strips and the fact that they are transparent materials ie. virtually invisible.
Your call - but you really don't know what you're missing. Cheers, Alex |
| Help with Decware SE84 Kit! | eeyore | Tubes / Valves | 1 | 27th January 2009 05:21 AM |
| wtb: decware power amp. | piwonka | Swap Meet | 3 | 28th October 2008 11:10 PM |
| Decware DFR 8 in Open Baffle | Glens | Full Range | 2 | 4th February 2008 02:29 PM |
| Decware OB: is this possible? | pjanda1 | Full Range | 3 | 29th January 2008 04:51 AM |
| Decware DFR8 & FE206E tweaks | bbaker6212 | Full Range | 0 | 22nd May 2006 08:08 PM |
| Page generated in 0.07790 seconds (71.40% PHP - 28.60% MySQL) with 11 queries |
