Old 9th January 2009, 05:13 AM   #1
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Default New BIBs and a tube amp Q??
I "finished" my first set of BIBs tonight. Well, finished enough to listen to them. I must say, I'm impressed. Even my wife was impressed. I used an old set of MCM 55-1870 5" aluminum drivers I've had for a few years. They needed a little on the higher freq side, so I added some Zenith horn tweeters I salvaged from an old console. I need to finish making them "airtight" and mount a bottom plate on them. After that, it's just cosmetics. I'm running them off an old RS STA-100 for now.
http://www.audiocircle.com/gallery/t...php?album=2584
Thanks Zilla for your BIB calculator.
A question about an old Packard Bell tube amp: it has a transformer for each channel that the original speakers were connected to. If I don't use the speakers that were originally with the amp, do I need to run the newer speakers (my new BIBs) from the transformers?
Thanks,
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, JBL L40 Speakers (recapped)
Old 9th January 2009, 08:12 AM   #2
tentoes is offline tentoes  Canada
You must connect the speakers to the output transformers on the tube amp. I gather this is an old console tube amp. Do you know the impedance of the old speakers?
It may not be wise to connect speakers with a lower impedance. Some output transformers do have taps for 4, 8 and 16 ohm speakers.
Good luck and use caution. Those old tube amps have 300-400V inside them and they can bite!
TT
Old 10th January 2009, 04:19 AM   #3
Godzilla's Avatar
Neat! Maybe put the tweeters on the rear... works for me!
http://www.zillaaudio.com/fostex-165k-bib.htm
Godzilla
New Marantz Receiver and BIBs! mikje Everything Else 0 5th January 2009 03:40 AM
BIBs and Suprabaffles greenie512 Full Range 0 23rd September 2008 08:28 AM
Regarding BiBs, ML-TQWP fwater Full Range 13 30th December 2007 08:23 PM
Bigger BIBs AGAIN jamikl Multi-Way 3 12th November 2006 04:21 PM
Page generated in 0.08886 seconds (61.77% PHP - 38.23% MySQL) with 10 queries
