Old 8th January 2009, 07:11 AM   #1
Raphael Shaw's Avatar
Default ML TQWT for Fostex FE167e
OK, So I've decided I like the FE167e, and I can get it fairly easily.
And I'd like to try a TQWT (Tapered Quarter-Wave Tube), and it seems like ML (Mass Loaded) is a good idea.
So... my plan is to build a ML TQWT for the FE167e (like the thread heading suggests).
So far I'm looking at building the Demetri which I saw at Planet_10 hi-fi.
http://www.planet10-hifi.com/boxes-fostex.html#demetri
Is there anything I need to know about before I go ahead with this?
Let me just say, I don't have much experience, and I have limited knowledge when it comes to building speakers.
So I'm looking for something which is "tried & tested". I don't wan't to be calculating resonances, or comparing graphs.
-Raphael
-R.Shaw
Old 8th January 2009, 07:25 AM   #2
Default Pointy Ends?
One thing I'm a little worried about with the Demetri design, is that it extends right to a point.
I can't recall why at the moment, but I vaguely remember that to be a bad thing, and that there should be a small surface area at the small end of the taper.
Any thoughts??
-R.Shaw
Old 8th January 2009, 08:11 AM   #3
planet10's Avatar
Default Re: Pointy Ends?
Originally it didn't, but the work Scottmoose did on the design showed that it made little difference, so we just left the endstop piece out. You do want to have fairly dense stuffing at the point.
Another design to consider is MJK's original ML-TQWT.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th January 2009, 08:38 AM   #4
Default Compatibility?
Thanks!
Yes I like MJK's Design very much.
Any Idea about sonic differences? I need something to base my decision on. I'm not worried about the wood-work, and both are fine aesthetically.
Can I just dump the FE167e MJK's box? (designed for FE164), or will I need to make any adjustments?
-Raphael
-R.Shaw
Old 8th January 2009, 09:41 AM   #5
planet10's Avatar
Default Re: Compatibility?
Yes.
dave
Old 8th January 2009, 05:21 PM   #6
chrisb is offline chrisb  Canada
I haven't heard the MJK design, but I can tell you that Demetri definitely performs ( I daresay no BSC required on this puppy), and while it certainly depends on the individuals, passed the WAF around here.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 8th January 2009, 05:30 PM   #7
Scottmoose's Avatar
FYI, a throat area (if a cabinet expands toward the terminus, it's technically a horn) of 0 isn't actually a bad thing if used properly -quite the reverse in fact as you get the maximum pipe-gain.
Old 9th January 2009, 06:57 AM   #8
Default Thanks
-Thanks
What do you mean about "maximum pipe-gain"
And Thanks generally for the input guys.
I'm still undecided about which one to go with though.
-I think a good question to ask would be: "which one will be more versatile when it comes to amplifiers, and music styles?" I have a very diverse musical taste, and although they will mostly be running on my home-made 10W 6l6 tube-amp, I'll probably be connecting them to anything with an 8 ohm output, tubes or no tubes.
-Raphael
-R.Shaw
Old 9th January 2009, 07:36 AM   #9
planet10's Avatar
If you ignore the LF these will be more similar than different... i've not heaed a set of the MJK pipes, but speaking in general terms based on experience & supposition:
1/ the wider baffle of demetri will give it a greater diffration signiture, but lowers the point at which baffle step occurs. Placed close to a wall, no BSC will likely be required. The diffraction signature can be larger ameriolated by using a supraBaffle to optimize wavelaunch and minimize late diffraction
2/ the high aspect ratio vent in Demetri is intended to minimize tuning errors due to the dynamic variability of driver (T/S) charateristics (it is like a resistor in series with the port). You lose some port gain (countered somewhat by the greater pipe gain due to the port), and in my experience gives the bass a sense of greater control (i always seem to by putting a wad of damping in the ports of BR, ML-V, and ML-TLs to kill what i feel is too much boom...
3/ cosmetic... i actually prefer the look of the MJK ML-TQWT (althou i'd change the presentation of the taper), Demetri with the 167 looks a bit out of place on the broad shouldered Demetri, this could be decreased i expect by dramatically rounding the top corners -- buit some would say that would make it look too much like a tombstone. Somewhere deep in my notes there is the basics of a slightly smaller monolith specifically for the 167 (not likely to go quite as low (maybe good, maybe not)
dave
Old 9th January 2009, 09:48 AM   #10
Scottmoose's Avatar
Default Re: Thanks
It means you get the maximum gain from a pipe of X length & volume. Smaller the throat, the higher the pressure.
WTB: Fostex FE167E Studley Swap Meet 0 25th June 2008 07:46 PM
Shouty FE167E in ML TQWT ghisdal Full Range 39 18th April 2007 11:14 PM
WTB : Fostex FE167E Cacophonix Swap Meet 0 11th April 2007 11:49 PM
FE167e: Brines MLTL or folded King ML TQWT? roundel325 Full Range 5 15th October 2006 06:19 AM
Aw ****. SI + Fostex FE167E disconnec Class D 8 29th September 2005 01:53 AM
Page generated in 0.12616 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
