Old 29th December 2008, 03:06 AM   #1
Question Can anyone help TL or ML-TL for Alpair 10
Im interested on Alpairs driver, i built JX92S GM's ML-TL which works nicely, real bass and overall balanced.
but now i'm interested to try Alpair 10 bass and Alpair 5 combination in TL box, which should look nicely and erase the necessity for the stand if its ported.
i'm sure it will perform very good.
GM or any one can help
here's the spec
Imp-nominal 6Ohm
Revc 5.4Ohm
Fo 35.0Hz
Sd 8.99mM/N
Vas 21.0Ltr
Cms 1.84mM/N
Mmd 10.73mKg
Mms 11.22g
BL 6.25T.M
Qms 2.37
Qes 0.35
Qts 0.30
Levc 288.727uH
No 0.25%
SPLo 86.2d
Xmax(1way) 9mm
Power 35watts cont.70watts max
http://www.markaudio.com/sites/all/f...air10_bass.jpg
Old 29th December 2008, 08:33 PM   #2
GM is offline GM  United States
GM's Avatar
Default Re: Can anyone help TL or ML-TL for Alpair 10
Greets!
0.31 ft^3/45.6 Hz T/S max flat:
L= 22.9"
CSA = 23.41"^2
zdriver = 8.6"
zport = 2" x 7" long near/at bottom
Vb = Vas, Fb = Fs MLTL (long):
L = 47.43"
CSA = 23.41"^2
zdriver = 14.85"
zport = 2" x 6" long near/at bottom
All dims i.d. and approximate. BSC will likely be required if not up against a boundary or two, so combined with a low Pe, strictly a near-field app/small room driver unless used in pairs with 2x power.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th December 2008, 05:30 PM   #3
Hi GM,
much appreciated
u know what, i will do some prototype
why is strictly near field? not enough SPL? how about if we made it longer Line, would it improve the SPL?
thanks
Cheers
Old 31st December 2008, 07:31 AM   #4
GM's Avatar
Greets!
You're welcome!
Low efficiency and power rating = low dynamic headroom unless the music is highly compressed, such as R&R. If BSC is used, then another 3-6 dB of efficiency/dynamic headroom is lost.
A longer line would just shorten the vent due to higher damping, so if you want to try a longer one, then a 56" i.d. with the driver down 16.81" and a 2" x 4" long vent is the max length without putting the driver too far off axis WRT typical seated ear height.
GM
Alpair 7 - out of the bag markaudio Full Range 16 27th November 2009 01:30 PM
Alpair 12 - also out of the bag markaudio Full Range 23 23rd November 2009 04:48 AM
Alpair 10 and 5 Combination _henry_ Full Range 19 1st June 2009 09:24 PM
alpair 10 box width ? norman bates Full Range 9 15th May 2009 04:54 AM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
Page generated in 0.08663 seconds (70.46% PHP - 29.54% MySQL) with 10 queries
