not a bad match in stock Karlson 15 - cone motion is reduced, better controlled than my AN10 in reflex which has dynamic offset and distortion at low levels. Theres quite a bit of beauty on Gary Karr's "The Spirit of Koussevitzsky" I think the rear lowpass gap might be tightened as theres a bit too much ripeness probably due to qts higher than optimum. I'm using a lowly Behringer EP2500 - -a solid state amp with cleaner front end more open top might sound nicer.
this is something to consider.
