Old 22nd December 2008, 09:30 PM   #1
IG81 is offline IG81  Canada
IG81's Avatar
Default BIB question
Ok, so to me the BIB design seems like a back-loaded, folded horn. The position of the driver (Zdriver parameter) is not at the complete throat of the horn, whose lenght is ½FS. So what does the 0.217 Zdriver ratio relate to?
And is it possible to reverse the design upside down so the mouth of the horn points towards the floor, assuming I would keep it above the floor just enough?
Thanks!
Old 22nd December 2008, 09:43 PM   #2
gurley123's Avatar
I know it's a monster thread, but I believe that they want all BiB questions in the BIB thread.
AFAIK the .217 Ratio is used for proper control of the half-wave resonance. Yes you can flip it (then it's called an I-BIB or inverted BIB.) A lot of people have done this and all the information is in the BIB thread. Basically you make an opening in the bottom rear equal to the original mouth area. Some have gone with a diagonal opening also. When doing an IBIB, you can use a ratio of .416(Line) to keep the driver near ear level. This is mostly done with the higher tuned ones (100~70HZ or so.)
Check the main thread for the full story.
Old 23rd December 2008, 02:59 PM   #3
IG81's Avatar
I was not aware of a main BIB thread at the moment I posted that, but I stumbled upon it afterwards. Thanks for the info, I'll gladly check it out!
Old 23rd December 2008, 03:44 PM   #4
gurley123's Avatar
It may take awhile, it's a monster thread but it's full of good information.
Old 23rd December 2008, 03:46 PM   #5
Scottmoose's Avatar
Briefly, yes, the BIB is a BLH -a tapped, chamberless, conical corner-horn to be exact. Tap length (Zdriver) is taken to minimise harmonic ripple as far as practicable. Inverting is no problem, plenty have been made like that.
Old 23rd December 2008, 04:22 PM   #6
Speakerholic
Cal Weldon's Avatar
Be careful
http://www.diyaudio.com/forums/showt...13#post1674813
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 23rd December 2008, 04:31 PM   #7
gurley123's Avatar
Wow, I had no idea. That's monstrous :P
Anyone want to buy some used cable? I make most of my own these days.
I need to get cracking on some BIBs myself.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.11092 seconds (71.89% PHP - 28.11% MySQL) with 10 queries
