Evening all....
Whilst most here enjoy the extended range of a single driver, there are many that suppliment either end (sometimes both) with an additional driver to suit their musical tastes. I'm interested in a free lunch crossover for a potential two way project, a D9nf on top and a ten inch driver to suppliment the bass. I wish to avoid the timing/phase shifts associated with a conventional crossover. Is it feasable to crossover completely accoustically (I'm guessing around 100Hz) and of so, what's the cost accoustically ie what do I compromise in doing so? Thinking aloud from an ignorant perspective : For high pass I understand that the baffle width of an open baffle reaches a cancellation frequency and for low pass maybe a 4th order bandpass "sub"? |
#2 |
The one and only
You will not be enjoying freedom from "timing/phase shifts" with
that approach, but that doesn't mean that it might not sound good.
#3 |
Thanks for the gentle warning Nelson
(and thank you too for your new Fs plots on the d9's)... |
#4 |
Speakerholic
Consider bi-amping with a plate amp for the bass driver.
#5 |
Thanks Cal, but I've a pair of Graaf GM20 OTL's availible so 4 x 20W's on tap... I'd much prefer to run each driver directly if it's possible.
I can eventually high/low pass passively at line level (I've an active Pass XVR1 to experiment with first) as I've suplus gain after my DAC but I was wondering if I could do it without any extra components ie accoustically..... My other option I suppose is to mono the amps giving 70wpc and use a passive series xover but I'd much prefer the former, it seems a more efficient design |
#6 |
The one and only
Something I have seen work well is the Velodyne V10 product (occasionally
on sale at Fry's for $149) sitting below the FR in a baffle or even a box. The frequency, level and phase controls are functional and I have used it without any crossover on the FR. The result greatly exceeds expectation. |
| Full range plus supertweeter in the nearfield: cap or real crossover? | HeatMiser | Full Range | 31 | 9th November 2004 12:39 AM |
| Second driver crossover point/full range | The Paulinator | Multi-Way | 17 | 21st January 2004 07:01 AM |
| active crossover vs. full range | Vix | Multi-Way | 4 | 7th January 2004 06:37 PM |
| Subwoofer/full range driver crossover freq? | kcreeger | Subwoofers | 1 | 11th June 2003 07:38 PM |
| Page generated in 0.07565 seconds (76.21% PHP - 23.79% MySQL) with 10 queries |
