Ok,
I am setting up my 2.1 system using modified tangband w3 881s in an aluminum/concrete 2 liter tear drop shaped speaker and subwoofer crossing over at 120hz. The enclosure is sealed giving me a 12 db octave slope at around 120hz and since I will be using a Sonic Impact t-amp with modified input cap of around .06uf I will get another 6db highpass. The problem is dividing the signal so I can send a summed mono signal to the subwoofer (mirage nano). A search resulted in the following schematic. Does this seem ok? http://www.rane.com/pdf/ranenotes/Why%20Not%20Wye.pdf Probably i will take the signal from cd player, into preamp then divide it into two (using rca dividing jack) and send one stereo signal to the sonic impact and the other to the circuit as described above and then to the sub. Does this seem ok? or is there a better way. Any help is appreciated. |
| Advice needed to build new 3 way active system | Zeverin | Multi-Way | 35 | 7th September 2010 11:56 AM |
| - Working On My Home System Help Needed - | HK_M3 | Solid State | 0 | 21st May 2006 06:59 AM |
| EQ needed for high-end system: Rane, Behringer, Presonus, etc | highdudgeon | Solid State | 2 | 21st November 2005 03:59 PM |
| Guidance for my new 7.1-System needed (Center, backward-Speaker) | Blitz | Multi-Way | 1 | 16th May 2005 06:32 PM |
| Help needed choosing a stereo component system in Mumbai (Sonodyne or Norge)??? | parsh78 | Chip Amps | 0 | 29th June 2004 05:50 AM |
| Page generated in 0.06105 seconds (69.81% PHP - 30.19% MySQL) with 10 queries |
