Fostex FE206/207 or others - Page 4 - diyAudio
Old 19th December 2008, 12:53 PM   #31
wow those look cool
Old 19th December 2008, 02:40 PM   #32
JC951t is offline JC951t  Taiwan
Hi Hm,
Nice. Is this a la Isobarik configuration ?
Old 19th December 2008, 04:54 PM   #33
hm is offline hm  Europe
hm's Avatar
Hello,
thanks,
itīs a bipol double horn
http://www.hm-moreart.de
Old 19th December 2008, 05:02 PM   #34
chrisb is offline chrisb  Canada
Originally posted by JC951t
Hi Planet,
As per your advice that the 167E would sound better,
would it be feasible to build a 2X 167e in the G Chang
cabinets ?
Thank you
Scott might say, "groan" - these enclosures are highly tailored to specific drivers, generally intending to adhere to the Single Driver approach. Just because there might be enough room on the front baffle to add extra or different drivers, won't ensure enhanced performance.
p.s. Did I forget to mention "combing"?
but then again, I could be all wet
Hi Hm,
no - each driver loads a separate horn
p.s. - sorry Horst, I didn't mean to step on your toes
on hiatus
Old 19th December 2008, 05:33 PM   #35
hm's Avatar
Hello,
you didnīt read "about what" in the middle
http://www.hm-moreart.de/11.htm
membran movement cross setting
and bass horn mouth distance.
better look the IMP measurements
of the sub Fanfare,
both horn parallel,
long,
short horn
than you can get it:
http://www.hm-moreart.de/107.htm
Old 19th December 2008, 05:42 PM   #36
Horst:
even if this was in concise English, it would probably be over my head - but thanks for the correction.
So the "divider" between the 2 drivers is the soft fibre-board material?
on hiatus
Old 19th December 2008, 06:00 PM   #37
hm's Avatar
chrisb,
take the german explanation and translate
by google translate,
all dark material is "Weichfaser"
http://www.hm-moreart.de/91.htm
Old 19th December 2008, 06:54 PM   #38
Scottmoose's Avatar
Originally posted by chrisb
[B]Scott might say, "groan" - these enclosures are highly tailored to specific drivers, generally intending to adhere to the Single Driver approach. Just because there might be enough room on the front baffle to add extra or different drivers, won't ensure enhanced performance.
No groans today (I'm not feeling well enough to even do that), but yes, agreed on all counts. Assuming it was retuned, you could run two drivers on the front baffle & roll one off above its mass-corner, but that's about it -aside from Calhoun none were designed for a semi-omni polar response so sticking a driver elsewhere isn't going to work too well.
Old 19th December 2008, 07:21 PM   #39
hm's Avatar
Hallo,
here a double study with two frontdriver,
the drivers of the Posaune are near as your my ears,
single driver localisation with more soundstage,
april i compair TUBA with KORNETT,
Kornett with 1/2 size, gets better soundstage
and better bass.
Old 19th December 2008, 08:59 PM   #40
Scottmoose's Avatar
Originally posted by hm
Hallo,
I assume you're rolling one off to avoid output lobing?
Enclosures for Fostex FE206 ESR + T90A-EY sierra_gva Full Range 32 25th May 2009 02:58 PM
First timer, Fostex FE206 + FE208sigma + Marantz john_dikeman Full Range 25 20th March 2009 12:01 AM
Holes in fostex FE206 BLH????? chris12345 Full Range 2 5th December 2006 07:57 AM
Advice on cab design for Fostex FE206 Analogue_Adam Multi-Way 0 6th November 2005 09:02 PM
Copyright Đ1999-2017 diyAudio
