Fostex FE206/207 or others
Old 16th December 2008, 01:58 PM   #1
JC951t is offline JC951t  Taiwan
Default Fostex FE206/207 or others
Hi Guys,
This is my first post in this forum. Have a couple of question that needs your expert opinion
1. which is the better speaker, the 206 or 207 ?
2. Is there any other brands in this price range which
is better. meaning overall smoothness
3. decware is selling a phase plug for the 206.
does it reallly improve the sound ?
4. Will build either a G Chang or Bruce cabinet. between
the 2, which one sounds better ?
Sorry, have never been into single driver speakers. Need
all the help that I can get.
Thank you all in advance for the advice
Old 16th December 2008, 03:50 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Fostex FE206/207 or others
With the mentioned enclosures, 207 will be best (since that is the driver the boxes were designed for). Choose a box designed for the 206 and it will have the edge. The FExx7 drivers in general are smoother than the FExx6 drivers and they go into easier to build (simplier) cabinets.
Hard to beat Fostex for the price, lots of enclosures for them, and driver modifications are fairly well documented.
I can't speak for the Decware ones* but the whizzer cone Fostex do get better/smoother with my plugs. Some consider them mandatory. http://www.planet10-hifi.com/pp-testimonials.html
*(i don't really like the idea of putting a vacuum tube, with all its rattly bits, right there in the centre of the loudspeaker where it is going to become a secondary sound source. We tried and published pictures of such an experiment at one of the diyFests (predating the Decware application by over a year) -- replacing the tube with a wooden plug proved better.)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th December 2008, 10:51 PM   #3
Hi Dave,
Thank you for he advice. BTW I was'nt referiing to the tube
phase plug from Decware. The one I'm talking about is like
a wave guide with a hole in the center
Thanks you
Old 17th December 2008, 12:29 AM   #4
Alex from Oz is offline Alex from Oz  Australia
Alex from Oz's Avatar
You mean this one.
Alex
Old 17th December 2008, 11:07 AM   #5
Hi Alex,
Yes this one. Do you have an experience with this ?
Old 17th December 2008, 02:32 PM   #6
hm is offline hm  Europe
hm's Avatar
Hello,
without any measurement in comparison,
it is for me like WIKI:
http://de.wikipedia.org/wiki/Phase-Plug
google translate helps
"Es ist also durchaus im Bereich der Möglichkeit, dass Hersteller Phase-Plugs zweiter Art einsetzen, ohne dass es zu eindeutigen Verbesserungen, die durch Messungen belegbar sind, kommt. Dieses wäre dann eine Art Modeerscheinung."
"It is therefore perfectly in field of possibility that manufacturers phase-Plugs second kind to use, without there being any clear improvements, the measurements are suitably comes. This would be a sort of fad."
http://www.hm-moreart.de
Old 17th December 2008, 07:17 PM   #7
No, but it is an interesting design concept.
Old 17th December 2008, 07:43 PM   #8
frugal-phile(tm)
planet10's Avatar
Yes... poking around in the shop... "wonder if this socket would work as a phase plug?"
Glad to see he finally went with a plastic imitation... a socket is really hard to remove after being installed.
dave
Old 18th December 2008, 11:56 AM   #9
beauistheman is offline beauistheman  Australia
so you say in a matched enclosure the 206 has the edge on the 207? I was under the impression that the 207 had nicer low end to it but ran out of puff somewhere around 12khz. Where as the 206 has more of a full range to it, but not as nice in the lower range as the 207 (in a matched enclosure). Please explain this to me as i am contemplating either of these 2 drivers myself.
Old 18th December 2008, 12:24 PM   #10
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Well, that's much it.
All else being equal the 207 sounds a bit smoother and more relaxed out of the box than the 206, whereas the 206 is more in your face and involving.
You can almost describe the difference as with the 207 you're watching a concert from a distance and can watch the entire stage and everything that goes on the time where 206 takes you to the front row or the mosh pit. What you prefer is up to you.
For upgrading I would prefer the 206 though as they sound incredible when mounted with a phase plug and an extra magnet mounted. My main caveat with the 207 is that you really need a supertweeter when you you want the most out of it whereas the 206s little lacking bass can be helped by the right horn or adding a (very good and fast) subwoofer to the setup.
Fostex FE206/207 or othersHide this!Advertise here!
Enclosures for Fostex FE206 ESR + T90A-EY sierra_gva Full Range 32 25th May 2009 02:58 PM
First timer, Fostex FE206 + FE208sigma + Marantz john_dikeman Full Range 25 20th March 2009 12:01 AM
Holes in fostex FE206 BLH????? chris12345 Full Range 2 5th December 2006 07:57 AM
Advice on cab design for Fostex FE206 Analogue_Adam Multi-Way 0 6th November 2005 09:02 PM
Copyright ©1999-2017 diyAudio
