Fostex FE206/207 or others
Old 20th December 2008, 01:12 AM   #41
JC951t is offline JC951t  Taiwan
Thank you for the advice guys.
So if I want to build the G Chang I would have to stick
to the FE207 for best results. I've read somewhere
that one can add an tweeter to extent the treble.
Advice, what kind of tweeter would work well with
the FE207 best ?
Thank you all
Old 20th December 2008, 08:55 AM   #42
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
FT17.
There is a slightly smaller design for the 167 as well, if you wished to go with the 6 1/2in unit.
Old 20th December 2008, 10:55 AM   #43
Hi Scottmoose,
You talking about the Chilli Chang ? I prefer to go with
an 8 inch speaker. May I ask, Is the FE206ES-R suitable
for this cabinet ? I would presume that this version would
sound better than the standard model. Yes, I understand that
the cabinets are specific for the FE206/207E but are there
other speakers that can be used with this enclosure. ? BTW
why is there a need to add a series resistor when using FE206 ?
Thank you for your advice
Old 20th December 2008, 05:13 PM   #44
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by JC951t
BTW why is there a need to add a series resistor when using FE206 ?
Because the FE206 needs to be made to look more like an FE207 to work in this enclosure.
From our experiments with Brynn adding the series R removes any advantage the bigger magnet driver may have. For this box i'd use 207.
People have been substituting Pioneer B20 as an inexpensive way to get started with the option of upgrading to FE207 later.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st December 2008, 12:36 AM   #45
Thank you planet
Old 30th December 2008, 01:42 PM   #46
Scottmoose,
Need your advice. Looking at the Half Chang.
What would happen if I were to increase the depth
of the cabinet & lower it's height but still maintaining
the same volume. Would the sound quality be affected ?
Thank you
Fostex FE206/207 or othersHide this!Advertise here!
Enclosures for Fostex FE206 ESR + T90A-EY sierra_gva Full Range 32 25th May 2009 02:58 PM
First timer, Fostex FE206 + FE208sigma + Marantz john_dikeman Full Range 25 20th March 2009 12:01 AM
Holes in fostex FE206 BLH????? chris12345 Full Range 2 5th December 2006 07:57 AM
Advice on cab design for Fostex FE206 Analogue_Adam Multi-Way 0 6th November 2005 09:02 PM
