Old 16th December 2008, 03:57 AM   #1
Default Fonken floorstander duct seal & damping
Hello, i'm getting ready to build the floorstander Mark II's. Does it help to do the Duct seal on the basket trick? What inner walls is the cotton or wool felt attached to? Seems like i've read all walls but the back wall. Does the holey board actually touch the back of the speaker?
I've read a lot of post about building Fonkens but haven't read a "Sticky" or any indepth post on building these. I have the Planet-10 drawing and a few pictures.
Old 16th December 2008, 04:11 AM   #2
TerryO is offline TerryO  United States
TerryO's Avatar
The Duct Seal works well for me. I might add that before Duct Seal, I used oil based modelling clay which also works pretty good, never hardens and damps well.
I've seen a "few" Fonkens over at Dave's and while I admire the design (and sound!), I have never constructed one. Dave, Chrisb or SCD can tell you what you need to know as far as cabinet damping is concerned.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 16th December 2008, 04:35 AM   #3
frugal-phile(tm)
planet10's Avatar
Default Re: Fonken floorstander duct seal & damping
Yes. Yes (i'd do the back wall too -- just not near the vent exit). Yes.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th December 2008, 06:32 AM   #4
chrisb is offline chrisb  Canada
Well, these are a considerably easier build than the original stand-mounted Fonken, so I guess we considered an assembly log unnecessary. Plus, I tend to accelerate the construction process, and taking photos is generally the last think on my mind, and I usually need to drag Dave into the shop for that.
Yes, we like to fit the driver brace as tightly against the magnet assembly as possible - which generally requires the driver to be temporarily installed for accurate measurement.
If you build with the lower void cavity, I'd definitely recommend filling with inert ballast - as much to stabilize the slender enclosure as to attenuate resonances.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 17th December 2008, 03:00 PM   #5
Thanks for the info guys, i've found a few more build pictures and hope to get started soon. I'll fit the drivers tight against the brace/holey board. Do i need to insulate one side of the holey board and not cut out the insulation for the holes? I saw this on one Fonken build.
Old 17th December 2008, 03:14 PM   #6
frugal-phile(tm)
planet10's Avatar
Yes.
dave
Duct Seal in automotive dampening dmongrain Everything Else 4 24th March 2009 01:46 AM
Fonken Floorstander m4rs Full Range 6 18th March 2009 12:19 PM
Duct Seal in the UK SimontY Parts 19 21st February 2009 12:57 AM
Duct Seal the Radio Shack 40-1310 ?? Sam Odom Multi-Way 2 25th March 2006 10:00 PM
found: online source for duct seal faustian bargin Multi-Way 1 1st December 2003 01:06 AM
Page generated in 0.08350 seconds (76.76% PHP - 23.24% MySQL) with 10 queries
