Old 14th December 2008, 10:02 AM   #1
Default First FE206E enclosure
hey all this will be my first fostex speaker build. Now im in japan and found how cheap the fostex speakers are, and wanting to build one for ages i finally got around to buying a pair. So i checked these links:
Compendium of Fostex FE206E designs
Floor standing cabinet for FE207e+FT17H ?
Now im not sure about the enclosure, i wanna build something to too complex (i am good with wood tho) and get good range from the speakers, low and high. Im comtenplating the half Chang from what one of the threads mentions.
Also, im considering going 2-way with the 206e and a ft17h (since they are just over 30 bucks here). So what about an enclosure for that? Just add a small seperated box ontop? What about wiring thu to the main box, wouldnt that cause leakage? Also what about crossovers, any suggestions?
The other option ive heard is good for the 206 instead of a tweeter is phase plugs. Better off doing that? Where do i get em.
Thanks in advance
Old 14th December 2008, 10:12 AM   #2
atm im thinking the half chang or this type of DBR?
http://ptsoundlab.ifrance.com/secenc...lb/angellb.htm
Old 14th December 2008, 11:24 AM   #3
bluemartini's Avatar
Planet10 has the phase plugs at this url
http://www.planet10-hifi.com/pp-info.html
Old 14th December 2008, 11:53 AM   #4
meanman1964's Avatar
Look over here http://www.hornlautsprecher.de/ and here http://gboers.xs4all.nl/daisy/home/g.../replikon.html
Old 14th December 2008, 12:03 PM   #5
any advice on whether i should use tweeters or phase plugs? The tweeters are almost cheaper to buy (also free delivery). Also, how does the fostex recomended double bass reflex enclosure sound?
Is this TL box OK for FE206E? RWBadley Full Range 11 27th January 2011 10:42 PM
BIB for Fe206e gunnet Full Range 24 26th March 2009 03:07 PM
enclosure for fe206e play from 40-300hz Fostex206 Full Range 5 17th September 2007 06:41 PM
FE206E Recommended Enclosure Skitch72 Full Range 13 24th October 2005 05:08 AM
FE206E enclosure tonitze Full Range 59 6th August 2005 02:41 AM
Page generated in 0.07688 seconds (77.99% PHP - 22.01% MySQL) with 10 queries
