Old 12th December 2008, 11:12 PM   #1
AllenB is offline AllenB  Australia
Default Enclosure for crossed over fostex
I want to build a box for my Fe108e sigmas that I want to use with my tapped horn sub. I think I'll cross the sub over at 100Hz and I don't think I'll need a horn with the fostexes because of the crossover frequency but I'm not sure. I'm thinking of a small closed box with a suprabaffle. Does it sound OK? How should I cross it over? I can do active or passive if it's best.
Old 13th December 2008, 12:44 AM   #2
GM is offline GM  United States
GM's Avatar
Default Re: Enclosure for crossed over fostex
Originally posted by AllenB
Does it sound OK?
Not really, this driver wants a ~1.1 L sealed cab based on published specs and at minimum an XO point at its F6 around 134 Hz, but it ideally needs a mid-bass/lower mids system filling in between ~500 Hz and a somewhat lower TH XO point (< 80 Hz).
Active is best with low XO points due to high parts cost, insertion losses.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th December 2008, 02:43 AM   #3
Thanks GM.
So if I understand, you're saying that without a BLH or something, there will be a loss of sensitivity below 500Hz. Even if I did baffle step compensation, I'd have excursion issues? So I'll have to either use a horn or a different sub?
Old 13th December 2008, 04:31 AM   #4
GM's Avatar
You're welcome!
Right, it starts running out of Xmax, but the main thing is you're asking a ~3" dia. driver to pump out a near 4 ft dia. WL at up to rated power and it just falls apart since it's designed to be a wide BW tweeter. This driver is already dynamic headroom challenged, so you want the TH and filler driver or 108 BLH to be the BSC.
GM
Old 13th December 2008, 08:00 AM   #5
OK, so it looks like I need a horn that goes up to 500Hz.
One thing, If I make the front baffle big enough for a wavelength at 100Hz, will it mess up the effect of a BLH?
Old 13th December 2008, 04:13 PM   #6
GM's Avatar
You've 'lost' me, please elaborate.
GM
Old 13th December 2008, 04:39 PM   #7
LilMik is offline LilMik  Germany
what about the metronom?
The Metronome
sounds already stunning fullrange . if you use a sub under 100 hz, it even gets better . but you have to use a bsc, that's right.
the 108es, a nice little driver , though not easy to handel.
greetings from germany
Old 13th December 2008, 08:02 PM   #8
GM
I'm thinking of doing a frugel-horn and what if I made a suprabaffle that is much bigger than usual that boosts frequencies much lower than 500Hz. This is where the horn would be boosting the response and I don't know what to expect from them both together.
I looked at that and I like it but I want an enclosure that gives some boost up to 500Hz.
I've listened to this speaker already in a box for another speaker and I really like it and I like the way the highs don't sound harsh and stand out like tweeters sometimes do.
Greetings to you too.
Old 13th December 2008, 09:34 PM   #9
frugal-phile(tm)
planet10's Avatar
Ron chose the supraBaffle size specifically to meet the gain from the horn.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th December 2008, 11:23 PM   #10
Oh, I'll leave it as it is see how I go. I've been reading good things about the frugalhorn.
Also some don't agree but I think they have WAF. Hopefully if I veneer them well they'll take the focus off my TH
Fostex 108 Small Enclosure Ronmeister Full Range 39 23rd February 2009 01:55 AM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
best enclosure for fostex fe103 jesserparker Multi-Way 10 3rd August 2005 04:05 AM
Fostex Enclosure Kofi Annan Full Range 34 2nd July 2004 01:18 PM
Fostex FF165K enclosure Ralph Multi-Way 3 21st April 2004 12:04 PM
Page generated in 0.16271 seconds (55.25% PHP - 44.75% MySQL) with 10 queries
