#1 | |
Hi all,
I'm in the middle of building Ron's Dallas II horns for the FE-206E. I have already bought all the wood and it's cut to boards. I still haven't ordered the 206E's. Yesterday I found a deal to buy a pair of newer used 208E + T90a tweeters. So, my question is: What modifications would be necessary for Dallas II to best accommodate 208E? Your thoughts on how would the 208+t90+dallas combo sound? I have found this quote from Ron on the forum Quote:
All and any ideas about this combo would be helpful. Crossover freq for the tweet ? I was thinking a cap and a L-pad and freq. of about 10kHz . Suggested values for these? Placement of the tweeter? |
#2 |
Crossover freq for the tweet ? I was thinking a cap and a L-pad and freq. of about 10kHz . Suggested values for these? Placement of the tweeter? Never worked with the T90. I used a ribbon and just a cap. Dont remember the value, but any 2way XO calculator will work. Yep i XOed at 10Khz. Sorry but all the components are in a box on the bottom of a buncha boxes in my spare bedroom (aka junk room). One of the MAJOR problems of ppl building the DallasII is they dont recognize the importance of a TOTAL airtight seal of the driver to the baffle. One builder of the DallasIII did a really beautiful job on the cabs, then had the speaker wires running out the driver hole with NO sealent whatsoever???????? Then builders complain about lack of bass. ron |
#3 |
Ron, thanks for your reply.
I'll make sure everything is airtight. So no modifications to the design necessary for the 208 ? Isn't only a cap on a tweeter a first order crossover? Why use a 2nd order calculator ? Any comments on difference in sound quality 206 vs. 208 ? 208 are double the price of 206 and they need a tweeter. Your thoughts is this a worthy upgrade ? Has anybody directly compared 206 to 208 in the same BLH? Phase plugs in 208? I've seen 208 don't have a regular dustcap, do they benefit from phase plugs ? BTW Do you know for what wood thickness are plans on planet10's site for? I started laying the design down on the side panel, and noticed that the plans assume a different thickness. I'm using 18mm ply, and as that is the preferred size of ply, I thought that the plans would be for that size too. |
#4 |
Its a first order XO, i just used an online program for a 2way. Disregard the coil parameters, just use cap value.
208 has greater detail and smoothness,the 206 i found to have a harsh top end even with phase plugs. 18mm is the designed thickness. ron |
#5 |
I have the Fe208e sigma and T90a combination in a D-58es horn. I have played around with the crossover and found one capacitor of 1.0uF is the best. no need for an L pad, just wire it direct.
I have compared the fe206e and fe208e sigma and they are chalk and cheese. here are my thoughts: 1. 206 is exciting, but fatiguing in the highs. This did not improve as it 'run in', or with other mods. 2. 206 has reasonable bass and can be capitvating on well recorded material. Not too forgiving on poor quality recordings 3. 208 is smoother overall with a more even balance, better mid bass. 4. 208 is a little darker, less livelier (thats a good thing) and is forgiving on most material. A more classy performer. 5. In both, you will notice more detail and less distortion than a conventional speaker 6. i found both work well with classical music and small ensembles. not as effective with rock music or orchestral. 7. Both require little amplifier power and work best with tubes in my view. Have fund! |
#6 | |
#7 | |
Amp in charge of my future Dallas speakers is an AMP5 from 41Hz (bigger Tripath) and for backup a modded T-amp. |
#8 | |
frugal-phile(tm)
dace
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
#10 | |
Hi planet10, I contacted you over e-mail about your 206en. Sorry but the shipping thing didn't work out. Could you compare stock 206 to 208? I can get my hands on a pair of 208+T90A for about double the price of a stock 206. Do you think that's a good deal (is the upgrade worth the money)? Any ideas about 208 and phase plugs ? Do they need them? They don't have just a regular dustcap. I'll probably try to do a enable process on 208, first with pieces of duck tape for a try-out. Any thoughts on that ? |
| Dallas II with AER MK1? | tocaco3 | Full Range | 9 | 16th April 2008 11:19 AM |
| Fostex 208E-Sigma | TaaJ | Multi-Way | 10 | 12th October 2004 08:00 PM |
| WTB: Fostex FE206E or 208E | Brett | Swap Meet | 1 | 16th September 2004 01:24 PM |
| Page generated in 0.12588 seconds (81.91% PHP - 18.09% MySQL) with 10 queries |
