Old 8th December 2008, 11:17 AM   #1
Default FE207E + Eminence Delta 12 LF
Hi...
I just ordered two Eminence Delta 12 LF and want to combine them with my FE207E.
The Deltas will work in a vented 100 - 110 l cabinet.
All the guys in germany who did the Deltas with 8" FR (usually FE206E), put the FRs into a closed cabinet.
That's a good option and will definately work, but I'm thinking about OB!
Did anyone ever try an FE207E in an OB?
Fostex says, that this driver has 95 db/W (m).
Would he have those 95 dB in OB down to 300 Hz?
This is my first own project and I'm kinda excited
thnx
Martin
Old 8th December 2008, 04:18 PM   #2
Godzilla's Avatar
If the Fostex is in a sealed box how low does it go?
Old 8th December 2008, 05:57 PM   #3
GM is offline GM  United States
GM's Avatar
In theory, a driver's flat BW begins rolling off around (2*Fs/Qts) in 2pi space, or ~298 Hz for the FE207E, ergo OK to 300 Hz assuming the published specs are reasonably accurate and has a minimum baffle width around (4316.28/(298/2))*0.707 = ~20.48", but haven't compared it to any OB software yet, so Caveat Emptor.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th December 2008, 06:58 AM   #4
Hi....should go down to 100 - 110 Hz (-3dB)
Old 9th December 2008, 08:10 AM   #5
GM
Sounds good enough to try it!
Old 9th December 2008, 12:04 PM   #6
GM's Avatar
Great! Looking forward to a review, final design details.
GM
Old 9th December 2008, 01:14 PM   #7
Just an idea....something like that...
http://img385.imageshack.us/img385/1...blage02de9.jpg
Old 9th December 2008, 04:47 PM   #8
Pano is offline Pano  United States
Pano's Avatar
..........but haven't compared it to any OB software yet, so Caveat Emptor.
I did a quick run in Xlbaffle. Still 95dB at 300Hz but rolling off under that. It agrees with your numbers, Greg.
Baffle 20.5"W x 47"H.
Looks like it has decent bass response on OB - so it should be easy to mate the the Deltas.
Take the Speaker Voltage Test!
Old 10th December 2008, 10:04 AM   #9
Sounds good to me....i'll built them at the last days of the year.
Old 10th December 2008, 02:29 PM   #10
GM's Avatar
Cool, thanks for checking.
GM
Eminence Delta B 8 inch driver BudP Multi-Way 1 29th April 2008 11:56 AM
Fostex FE207E with Eminence Alpha 15 open baffle sharpi31 Multi-Way 15 21st September 2007 03:20 AM
Eminence Delta 12LFA is 10 ohm nom?! geminni Subwoofers 2 11th July 2007 06:49 AM
FS : pair of Eminence Delta 10" ***LOWERED PRICE*** punk Swap Meet 1 12th July 2006 03:08 AM
FS : pair of Eminence Delta 10" woofers punk Swap Meet 0 9th July 2006 06:52 AM
Page generated in 0.09073 seconds (78.27% PHP - 21.73% MySQL) with 11 queries
