What in your opinion is the smoothest driver you've owned?
I'll nominate the 871s as it's the one I always seem to go back to even after trying others. |
#2 |
frugal-phile(tm)
I found the 971 kinda choppy at the top... smoothest driver i've owned would be Fostex FX120
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Custom Title
MCM 55-1200. A 'wide range' rather than quite 'full' but very smooth
http://www.geocities.com/gordonwater...ker_specs.html 2nd or 3rd down
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#4 | |
I'm thinking about that driver since many months...how would you describe the difference between the FE127E (stock) and the FX 120? |
#5 | |
frugal-phile(tm)
Ignoring a couple dB less efficiency FX120 is a fair step up from stock FE127e. A fully treated FE127eN on the other hand has the edge on the FX120 as far as downward dynamic range and detail retrieval goes (again to an extent fue to the squashing of the cone's self-noise). The peakiness , althou suppressed to a great extent is still there. Listeners generally chhose the FE127eN over the stock FX120, as the FX120 sounds "fuzzy" in direct comparison. Solid evaluation of a treated FX120 (FX120eN) has been slowed down by clients scooping up my prototypes before we can do really serious eval -- they are very promising thou. Another pair is nearing the finish line on my bench, and plans for a 2nd iteration FonkenFX have been sent off to Chris to be built (short of an early concept for a biFonken, this will be the trickest Fonken yet to build, and will be exploring new territory) dave
#6 |
FE108ES II as far as "out-of-the-box", although I hope the FE138ES-R will be smoother when it breaks in.
The 108 took a few hundred hours to really loosen up. Maybe enabling would help? The FE166ES-R was rough on top without damping the basket & the gauze on the whizzer. That smoothed it out a lot. Robert |
#7 |
I'll second the FX120. The JX92S is "smoother" but I find myself listening to the FX120 more often right now. Likely a matter of personal taste. I like the paper cone, metallic dust cap of the FX120 sound. Everyone else who comes over prefer the JX92S.
Hope this helps.
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#8 |
For me, the FE166ES-R's, once they broke in, became creamy-smooth as hand-churned butter. They have a sweetness that I haven't heard elsewhere, regardless of price.
I'm breaking in some FE208-Sigmas in Bob Brines' LT-2000 cabs, and they amaze with their LF. The bass is fantastic, and the midrange is beauteous. But while they exceeded my expectations, they still aren't as silky-smooth as the FE166ES-R's. I don't think I could ever settle down with a single set of drivers -- many drivers do a certain trick exceedingly well. I haven't heard a single "best" driver yet. Every driver represents a different set of trade-offs. |
#9 | |
The one and only
#10 | |
you know, the one with the Brazilian Wax
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| L-pad attenuator for midrange driver 6 1/4 inch driver | rhythmdiy | Multi-Way | 0 | 4th November 2007 03:32 PM |
| Base driver to suit ESS Heil driver | gerado | Planars & Exotics | 6 | 1st August 2007 07:56 PM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Driver/ driver configuration improve soundstage width | andy2 | Multi-Way | 6 | 16th June 2005 08:47 PM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
| Page generated in 0.11874 seconds (81.76% PHP - 18.24% MySQL) with 10 queries |
