Hello everybody out there in diy-land.
A couple of years ago I bought a set of Lowther PM6C drivers. I have eventually put them to use, in a two-way open baffle. The result is interesting, BUT: at a bit of volume and at certain (high-ish) frequencies, there's a screeching/scratching noise from one driver. If I gently push the cone back at the whizzer, I can hear and feel the voice coil scratching against the magnet, like it's misaligned in the air gap. At least that's the impression I get. Now, how do I repair this? Is it possible to repair this whithout beeing an expert? Will staring or talking hard at the bad driver make it improve? Or should I try something else? Suggestions are welcome! HC |
#2 |
The one and only
Voice coil is possibly off center. If you have some non-magnetic wrenches
you can re-center it, otherwise you might need re-coning. |
#3 |
it is fairly easy to align lowther driver . Go to Lowther America website
and read "how to". I had a scratchy DX4 and fixed it without any problem. Just proceed carefully . Regards, L |
#4 |
Once you've sorted it, remember to rotate the drivers 180 degrees every few months, to compensate for the tendency of the suspension to sag.
#5 |
If you want my repair sheet, send me an e-mail and I will forward it to you. It is not on my website, which is about to get a major revision.
The sagging suspension problem existed when Lowther used natural foam rubber surrounds. These were known to sag over time, and for that reason were phased out a long time ago. New suspension and surrounds do not sag, and do not have to be rotated every 6 months.
Jon Ver Halen Lowther-America |
#6 |
Thanks for all replies.
I'd like to realign my driver if possible. Access to non-magnetic wrenches is possible. I'll ask my mechanical engineering ph.d. dad if I can use his extensive collection of tools. I took a look at the Lowther America website, but found no "how to"-section. Please supply link, and I will throw myself upon it and rapidly accumulate alignment knowledge. I hope. Lowther rules (probably)! Have a nice weekend, HC |
| Suggestions for new driver for sub | geoffstgermaine | Subwoofers | 0 | 8th March 2007 03:17 AM |
| Suggestions for this driver | Flavio88 | Multi-Way | 5 | 31st December 2006 01:38 AM |
| 70l Box Suggestions Requested | nayr2 | Subwoofers | 7 | 25th October 2005 05:52 PM |
| Driver Suggestions | renfrey | Full Range | 3 | 7th June 2005 07:13 PM |
| suggestions requested (pga2310 related) | blu_line | Solid State | 1 | 10th July 2002 08:20 PM |
| Page generated in 0.10331 seconds (70.92% PHP - 29.08% MySQL) with 10 queries |
