Old 2nd April 2003, 06:54 AM   #1
Default lowthers?
Hi all, I'm new to the hi efficiency game and could use some advice on the use of lowthers in a bass reflex box. Lowtherspeakers.com sells and has box desighns that look interesting, but do they work?
Do tell
Old 2nd April 2003, 08:52 AM   #2
analog_sa's Avatar
Apparently not very well. Lowther drive units are really not suited for bass reflex, not to mention they can't cope with large cone movements. Listen before you buy.
cheers
peter
Old 2nd April 2003, 09:01 AM   #3
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Lowthers are for horns....
high efficiency is horns..
the Lowther cabinets are AFAIK mostly horns...??
Here's an example which I find very interesting myself, both technically and aestethically....and there's lots of other...
Just a minor snag.....they are all big.........
http://www.vt52.com/diy/diypage/hedlund/hedlund.html
If you're in the cabinet making ballpark of carpentry, this is no problem...
WAF though................
Luckily, I was into big loudpeakers before I met my wife, so she has learned to appreciate them and furnish with the loudspeakers, not finding a place for them afterwards...
Old 2nd April 2003, 09:51 AM   #4
Digiphobe,
If you're willing to try a driver other than a Lowther, I'm currently building BR boxes for Fostex FE 208 Sigma drivers using Martin King's design found at http://www.quarter-wave.com Other BR designs for other Fostex designers appear on Madisound. Go to the catalog, click on Fostex and scroll all the way down. You may also want to browse the Single Driver website at http://www.melhuish.org
Good luck!
Old 2nd April 2003, 03:32 PM   #5
I’ve listened to a few Lowthers over the years (PM-2A, PM-7A, PM-6A, DX-3, DX-2, PM-6C) in a variety of cabinets (Medallions, Acousta, 2 flavors of Mauhorns, bass-reflex) and mostly loved what I heard with 1 glaring exception – the bass reflex – which I hated. I came close to jumping into Lowthers (was going to build Medallions) but ultimately heard Altec 604’s and was blown away – lots of the Lowther strengths like high efficiency, SET friendliness and that great point source soundstage but with the added benefit of great bass.
I noticed that you are in Canada so it might be a good idea to talk to the Canadian Lowther distributor to get his thoughts on drivers and cabinets. Scott’s a great guy with lots of experience on implementing these drivers at different price points http://www.lowtherclub.com/. Just my opinion, but I would stay WAY clear of using these in BR enclosures.
Billfort
Old 2nd April 2003, 05:48 PM   #6
Thanks for the advice guys, I'm sensing that a br style box is not the way to go for a lowther driver; also, unless the lowthers contribute an otherworldly listening experience I'm not sure It'll be worth spending 700$ on the drivers alone!
What I'm dealing with is 20 sep watts, and require a speaker that is more sensitive than my current 89db boxes. The single driver foster 208 may be an alternative, so might be an mtm design that's 93db + sensitive, but even then I seem to be stuck using expensive focal drivers (90$ a crack) In any case, I think it's better to build then to buy new.
The search continues..........cheers.
Old 24th February 2004, 07:52 PM   #7
Lowther loudspeakers are really for life. I've been using PM6C's for the past 20 yrs in acousta cases, with Sugden 10w class A amp. I've heard little to beat them on Classical music. If you're into pop with electronic sounds, then perhaps no. They don't have thumping bass, but the orchestral instruments sound as they do live. I spend a good deal of time recording orchestras, and chamber music, and it's always very revealing to bring the CD's home to listen to.
I've now upgraded to EX4 units with the Sugden, and am building 15W Linsley Hood (1996). Also intend to build TP1 cases for the EX4's. The EX4's are expensive, but revealing. No nasty peaks, just smooth transition from low to high frequencies.
Lowthers excel with low power amps. But use the factory designed cabinets...... Available on CD -rom. Any Canadian should really contact Scott @ Lowther Canada. He's helpful.
Old 24th February 2004, 08:21 PM   #8
zuki is offline zuki  United States
go to this link and on the left.
find cabinets.
then scroll down to the plans til you find the
" ACE PDF FILE" no photo, just file
i purchased the lowther ex 3 (?) drivers 2 years ago to make this ace design and have not built them yet.
just thought i would share.
i have heard the ace using the decware signatures.
the lowther/ace used a red french fry warming light in place of the phase plug.in each driver (shrink tube around bulb threads) so it could stand/face up/point up
sakura ota cables used with a linn table and graham arm and koetsu cartridge.
sounded very good ( i listen @ low volumes) enough for me.
with country music and female vocals.
very cool set up i thought
Lowthers worth the effort? Shaun Full Range 4 3rd April 2008 04:49 PM
Best amp match for Lowthers? gnugear Full Range 9 13th March 2008 08:58 PM
Thoughts on Lowthers? one1speed Full Range 7 27th February 2006 07:25 PM
Martin King's Lowthers planet10 Multi-Way 13 14th November 2002 11:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
