Old 2nd November 2008, 02:48 AM   #1
Default Which Fostex is this?
I've been given a pair of 4 inch drivers. Fostex 10F02C is written on the magnet. I haven't found those numbers on the Fostex site although they do look like the discontinued FE103.... Anyone know this code?
Old 2nd November 2008, 05:02 AM   #2
Sorry, I know nothing about them. However, I found these photos on a Google cached page of a previous eBay auction..
Old 2nd November 2008, 07:54 AM   #3
Thanks for those photos BHTX, They' re just like the ones I've got. I mounted them in a 6 litre vented enclosure that was lying around from a previous experiment and the result is promising. The bottom end is quite pronounced and a bit woofy, They might work better in a sealed box. the mids are fine. The top end is nothing to write home about, and would benefit from a tweeter maybe?but they're OK. Now if someone knows exactly what they are I will be able to make the right box for them and then I think they are a proposition.
Old 2nd November 2008, 03:05 PM   #4
frugal-phile(tm)
planet10's Avatar
An early ceramic magnet FE103
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd November 2008, 05:46 PM   #5
Speakerholic
Cal Weldon's Avatar
Interesting how they reverted to the numbering system from the Foster days.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd November 2008, 08:56 PM   #6
Thanks Dave. Is there a spawn family box that would work? If not it looks like a 3.6 L BR box might be the go.
Old 2nd November 2008, 11:27 PM   #7
frugal-phile(tm)
planet10's Avatar
Until you measure it, one would guess boxes designed for FE103... Suzy Chang or Solo 103 would be my call.
Those benefit from phase plugs.
dave
Old 4th November 2008, 05:49 AM   #8
Brisso57's Avatar
dave
Is this another ceramic "103"?
(It's from a Sony R2R)
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 4th November 2008, 05:56 AM   #9
frugal-phile(tm)
planet10's Avatar
It is from the same niche, you can see the inverted cloth surround, but has a smaller magnet than most.
dave
Old 4th November 2008, 06:11 AM   #10
Brisso57's Avatar
dave
I've not heard this one. Are the ceramic 103's comparable sonically to the alnico series?
ie Should I bother buying and trying? or stick to alnico?
Doug
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 06:00 PM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 01:35 PM
Fostex BLH boonedog Full Range 1 23rd March 2005 08:39 PM
Fostex FE 206 E in ML TL Again levon Full Range 0 16th April 2004 08:02 AM
Page generated in 0.11223 seconds (78.55% PHP - 21.45% MySQL) with 11 queries
