Fostex FE103E... - Page 37 - diyAudio
Old 27th December 2008, 06:48 PM   #361
GM is offline GM  United States
GM's Avatar
Originally posted by planet10
When we introed the Fonken167 at this years diyFest, 2 different Bob Brines FT1600 (ML-TL) owners said it was the best they had heard the driver.
Yeah, critically damped speaker systems regardless of box alignment type is where it's at SQ-wise.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th December 2008, 11:08 PM   #362
chrisb is offline chrisb  Canada
Originally posted by chops
If the Fonken167 is that good, then I think I should build those. I desire the best I can possibly get my hands on within my budget.
not a project for a single afternoon, but definitely worth the effort
I imagine the Fonken167's were using your modified drivers?
yup
... so, not as easy at it sounds, this letting go thing
Old 27th December 2008, 11:29 PM   #363
chops is offline chops  United States
chops's Avatar
I was gonna check out the plans for the Fonken167 only to find out that the link is bad. Pooh.
Charles
Old 28th December 2008, 01:20 AM   #364
frugal-phile(tm)
planet10's Avatar
Darn, i haven't fixed that link yet? I emailed you the plans earlier today.
They will only be available in detail for those that buy drivers or by donation (silimar program to Bob's). At the moment they are part of a beta program to get them into a condition that warants the (modest) tariff.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th December 2008, 03:34 AM   #365
chops's Avatar
They will only be available in detail for those that buy drivers or by donation (silimar program to Bob's). At the moment they are part of a beta program to get them into a condition that waeants the (modest) tariff.
dave
So you did! I didn't even notice that before. Oops... Thanks!
They're a bit on the short side for me, but I can build the bases up for them to compensate.
So does anyone have any listening impressions of these yet?
Charles
Old 28th December 2008, 04:18 AM   #366
frugal-phile(tm)
planet10's Avatar
1 pair exists. They were a hit at their intro at this last summer's VI diyFest. Chris took them over to his sisters, and we were only able to extract them long enuff to veneer them... after vebeer and before delivery Chris set them up in his (wife's) TC room and the Milevas are going to get replaced. We'll also have to do another set for demos.
They get the mids almost as well as the smaller Fonkens, have better, deeper base, better dynamics, and play louder with the small amps we are so fond of.
Chris can chime in, except for his sister, he has had more time with them than anyone else, including in his man-cave which is much the same size as yours.
The bases are purposely mutable so that the height can be adjusted for needs (including short of stature for WAF)
dave
Old 28th December 2008, 06:45 AM   #367
dave
Since the snow has prevented me from making that trek to the end of Mark Lane for the past 2 weeks, I'll have to rely the memory of my impressions from my last listening sessions.
The two specific driver/enclosure combinations (FE127 / FE167 & Fonken) are as closely optimized to the same goals as the driver's parameters allowed.
I have spent over a year and half listening to a series of FE127 Fonkens, with a variety of electronics and sources, and I think I have a pretty good handle on their strengths and weaknesses.
IMHO, in a direct head to head, the FE127 will still have a greater degree of intimacy and finesse from the midbass on up, particularly at lower volumes and in smaller rooms, as well as superior imaging focus and dimensionality of soundstage - but above 90dB average levels and in larger spaces, it's another story. As the cliche goes, (when it comes to SPL levels and frequency extension) there is simply no replacement for displacement. Think of the Fonken167 as the smaller system on performance enhancing hormones, but without the 'roid rage.
I could certainly live with them, without the need for bass support, but I suppose there will always be folks that need more. For those folks, we could always envision an F'n 207 - but I'd suspect those would definitely need tweeters.
For reference, I have 2 main listening rooms - my "small room" is approx 200ft^2 of usable space, and the larger is the family / TV room which is approx 320ft ^2. The room the 167s now inhabit is at least 800ft^ of very open space "great room" with 12ft ceilings and >30ft wall of windows overlooking the water.
Old 29th December 2008, 03:48 AM   #368
chops's Avatar
It definitely seems as though the Fonken's are the ones for me.
Since they do bass so well, I shouldn't have any problems crossing them over rather low, around 50Hz or so I would imagine. What do they extend down to anyway?
So you both covered bass and midrange with the Fonken167's, but how about the top end? How do they do in the upper registers compared to say the smaller 4.5" and 4" drivers? That's actually my biggest concern.
Adding bass to a system is much easier and cleaner to deal with as far as phase combing is concerned, but treble isn't as easy and clean, and is a lot more noticeable if not done properly. This is why I don't mind adding a sub or two, but am against the idea of adding tweeters.
Charles
Old 29th December 2008, 05:17 AM   #369
A bold statement here, and hope it doesn't further confound your decision tree: AFAIC, within the Fostex series under discussion, and notwithstanding EnABL, phase plugs, etc. , 4.5" siblings ( FE126/127 FF125k) outperform the larger whizzer-coned series (FE166/167) in the upper midrange and top end; and depending on the system and enclosure it's not just by just a smidge.
However - I don't listen very loud (almost entirely below 90dB peaks), and there will be situations in which the better compromise is to go for the larger driver's horsepower and low-end torque, at the minor sacrifice of handling on those tight radius slalom curves. That's it, my automotive analogies are all used up (and the combination of cold medication and Bison Grass Vodka kicked in hours ago....)
Having lived with the 167Fonken for a short while, and the 127s for much longer, I suspect it would take relatively little recalibration for me to fully to adjust to the larger drivers, and get back to listening to the music. However, as serenechaos and others have noted, we all have differing expectations, sensitivities and tolerance levels - so the only one who could say for sure what works for you is, well - you, and only after you've experienced both.
In other words, I love the Fonken-127 - it has all the intimacy any bass I need in my small room, but could probably easily live with the 167s in the larger room, which is (2 channel) video only. Presently that system has a pair of Mileva ( also a 127 based system), and does lack the visceral impact readily available from the 167.
If you consider adding bass to a system easier than band-aiding an ailing top end, and since you already have the 103's on hand, it could well be that something like the Solo103 and dual powered woofers could be a safe bet.
How low do the Fonken167 extend in a real room? I dunno - we haven't had a chance to build the second pair or measure them at my sister's yet.
Old 29th December 2008, 07:01 AM   #370
frugal-phile(tm)
planet10's Avatar
I found the top end of the F167 to be quite satisfying... i was fully expecting the F127 to be far ahead and it just wasn't the case.
dave
Recommend a woofer for Fostex FE103E tpsorin Multi-Way 7 9th August 2009 06:05 PM
Fostex FE127E vs FE126E vs FE103E bluegti Full Range 3 22nd February 2006 12:40 AM
Double Fostex FE103E horn Scottmoose Full Range 16 5th August 2005 08:50 PM
Copyright 1999-2017 diyAudio
