Old 28th October 2008, 04:12 PM   #1
Buzzy is offline Buzzy  Singapore
Default Any center speaker horn ?
Has anyone built a horn loaded center channel speaker for a 5.1 system ?
Old 28th October 2008, 05:22 PM   #2
hm is online now hm  Europe
hm's Avatar
Hello:
my SAT horns:
Trumpet, Schalmei, Horn and Flute
are made for Dolby Digital 5.1,
you need best also a sub bass horn.
http://www.hm-moreart.de
Old 28th October 2008, 06:08 PM   #3
GM is offline GM  United States
GM's Avatar
Which of your designs do you prefer?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 29th October 2008, 03:14 AM   #4
hwong is offline hwong  Canada
How about laying a fonken flat for a center channel?
Old 29th October 2008, 08:19 PM   #5
hm's Avatar
Hi GM,
Kornett
Saxophon
Schalmei + Alphorn
Old 4th November 2008, 10:48 AM   #6
dazydee is offline dazydee  Germany
dazydee's Avatar
He did -> Viech Center
Center Viech different fold
Upgrade your grey matter, 'cause one day it may matter
Old 24th December 2008, 01:02 AM   #7
HM
Like your designs. Interested to know more about the sub bass horns. How well do they integrate with the Visaton 200? Also, have you tried working with larger 12/15" drivers to build a double sub bass horn?
Welcome input from any DIYers with experience in sub bass horns ;-) Like the idea of having passive sub bass as long as the cabinet is relatively compact.
Old 26th December 2008, 05:57 AM   #8
hm's Avatar
Default Antripodean
Happy Xmax,
a few studies:
http://www.hm-moreart.de/100.htm
http://www.hm-moreart.de/105.htm
http://www.hm-moreart.de/98.htm
http://www.hm-moreart.de/106.htm
after testing two studies under feedback
http://www.hm-moreart.de/108.htm
TH only useful below 100 Hz, coloration
by driver position.
mass inertia of big basses are contra productiv
to fast FR in sat horns.
"about what":
Why do I mostly use small bass speaker?
The inertia of membrane mass slows the music signal, the smaller the volume level, in living room areas usual, the pronounced damped the moving mass of the diaphragm signal playback, the main reason for the lack of serious bass resolution of heavy
weight bass membranes.
B200 is useful in sat horns, TRUMPET, SCHALMEI, HORN
i like it very much, no whizzer,
for bass horns not useful because the high Qts.
DIY Proac Center speaker purist Multi-Way 50 23rd August 2007 08:16 AM
Center speaker into SF system weinstro Multi-Way 3 25th February 2006 05:52 PM
need a center speaker..help!! cybermunster Multi-Way 1 5th September 2005 04:19 PM
Center speaker Oxanest Multi-Way 3 11th June 2004 11:22 AM
Center Speaker with tb w3-871s Razorfist Multi-Way 11 18th June 2003 05:00 PM
Page generated in 0.08452 seconds (76.85% PHP - 23.15% MySQL) with 11 queries
