Old 22nd October 2008, 12:29 AM   #1
Default Fostex 208es horn stuffing
Hello there.
I am building the fostex recommended enclosure for the 208es,and i want to ask if anyone has tried stuffing the chamber behind the driver,or in the bottom of the cabinet.
Has anyone placed any stuffing on the wall behind the driver to eliminate any reflecting sound waves?
I would appreciate any help.
Thank you
Old 22nd October 2008, 01:40 AM   #2
The one and only
Nelson Pass's Avatar
I've done it many times, with varying results. Try several variations
and see what works for you.
Old 22nd October 2008, 02:04 AM   #3
adamt is offline adamt  Australia
Initially, the 208 requires a bit of stuffing in the compression chamber during burn in (up to about 100 hours). If you dont, it will sound a bit harsh at times. Thereafter, you can remove the stuffing to suit your taste.
I am over 300 hours, and have found a light stuffing to work for me. This seems to retain the speed and air of the driver.
I Stuffed the horn opening with a pillow to start with, but this put a veil over the music for me, and sounded muddy. I quickly removed it.
I also tried altering the compression chamber size with blocks of wood. Dont waste your time, the designer has optimised the chamber size for this driver, and I found it had a detrimental effect.
Enjoy, its a great driver.
Old 22nd October 2008, 10:46 AM   #4
Thank you both for your help.I appreciate it.
I will try adding stuffing with an extra set of ears helping me
Horn Enclosure for Fostex 206 Puffin Full Range 71 15th March 2009 09:25 PM
208es Fostex BLH mods ailouros6 Full Range 2 21st October 2008 12:54 PM
Stuffing and Port Length- Fostex 167 Pathmark Full Range 7 16th July 2007 05:05 AM
stuffing/lining a bass horn paulspencer Subwoofers 5 15th February 2007 06:47 PM
Damping / Stuffing a Horn Skitch72 Full Range 15 28th October 2006 03:57 PM
Page generated in 0.07965 seconds (70.11% PHP - 29.89% MySQL) with 10 queries
