Old 21st October 2008, 04:36 PM   #1
Default Adding a rear Ambience tweeter
Hi ,im still loving my Chilli-chang BVR horns.These have a Fostex 168E sigma driver and i find the sound wonderfull in my smallish room.Just a thought , Cain and cain fit a rear tweeter to one of their Abbey speakers . I would like to add just abit of ambience and air to the top end without destroying the imaging etc. This is just a thought and i wanted to know your opinions etc about fitting a rear tweeter to my speakers.Could i use a 1uf cap to roll it in ? what type of tweeter would suit the fostex a nice ribbon maybe ?
Old 22nd October 2008, 02:43 PM   #2
Speakerholic
Cal Weldon's Avatar
The type of tweeter is up to you. Keep in mind it will be rather forgiving when you fire it out the back so some have got away with a rather inexpensive unit and even, gasp, a piezo (not an endorsement). I would experiment with the cap, you will get away with going bigger if you need more presence.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 22nd October 2008, 04:24 PM   #3
Godzilla's Avatar
TC used this tweeter on the back of his Abby.
http://madisound.com/catalog/product...roducts_id=290
I am not crossover he used. I think it's a good idea. Try a 1uf cap and work from there.
http://www.zillaaudio.com/straight-pipe-1354.htm
I also used an L-pad to tune the tweeter to taste.
Godzilla
Old 23rd October 2008, 04:24 PM   #4
Default Thanks
Hi Guys I saw this tweeter and thought it might work.So if i use a bigger cap than 1 uf This will roll in the treble sooner is this right.? To adjust the level do i just use a resistor across thos tweeter what sort of valves etc.Thanks again james.
http://www.bmm-electronics.com/Produ...roduct_ID=6964
Old 23rd October 2008, 05:55 PM   #5
frugal-phile(tm)
planet10's Avatar
That tweeter is a bit overkill, and probably not quite efficient enuff... You want something the same or greater efficiency that the 168 and you can adjust the level with the size of the cap. You also don't need anything that goes really low, 5k probably will do you fine.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Rear firing "ambience" supertweeter? JoshuaTechnomage Full Range 6 24th May 2009 08:00 PM
Adding center and rear channels nebelk Multi-Way 2 13th March 2008 06:05 AM
Rear mounted ambience drivers, opinions? ptwining Multi-Way 5 20th December 2007 04:41 PM
Rear tweeter - Pros and Cons Sony Multi-Way 2 26th August 2005 03:34 PM
rear firing tweeter - why? bbaker6212 Multi-Way 5 25th September 2002 12:50 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
