Old 17th October 2008, 09:37 AM   #1
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Default What cabinet for lowther A45?
I may buy a cheap used pair but I don't know what cabinet to build. OK, I don't like back horns.
Point me somewhere, I am quite lost when speaking of speakers.
Ciao
Gianluca
Old 17th October 2008, 12:29 PM   #2
Scottmoose's Avatar
Default Re: What cabinet for lowther A45?
They're designed for back loaded horns.
If you must put them in something else, a simple MLTL should do the job OK in a small space & moderate volumes.
34in line
CSA = 43.5in^2
Zdriver 12.5in
Zvent 32in
Vent 2in diameter x 2in long. Stuff 0.45lbs ft^3 top 20in or line top, back & one side-wall.
Old 17th October 2008, 02:03 PM   #3
tarmac ripper
Gluca's Avatar
Hey Scott
thanks. Would you mind give me a link to some tech documentation explaining in deeper details your simulation? I am quite an absolute beginner with speakers.
Ciao
Gianluca
Old 17th October 2008, 02:08 PM   #4
Scottmoose's Avatar
When you say technical information, what exactly is it you need?
Old 17th October 2008, 04:28 PM   #5
tarmac ripper
Gluca's Avatar
Well... basically I never built a MLTL and I know little theory so I need to translate those numbers in dimensions to cut the wood and assembly the cabinet.
Thanks for the tips.
Old 17th October 2008, 07:09 PM   #6
Default Other options
Hi Gianluco
One customer loves them in Terry Cains BIB boxes.
Open baffle works.
Others like them in a .5 cubic foot boxe, with a woofer below 150 hz.
These typically have a rising high end that can be tamed by listening off axis or adding a 1mh coil with a 10 to 15 ohm resistor. Place the resistor and coil parallel with each other, and that combination in between + amp and + of Lowther.
Jon Ver Halen
Lowther-America
Old 17th October 2008, 07:19 PM   #7
Scottmoose's Avatar
Internal dimensions 34in tall. Whatever WxD dimensions you prefer which give the stated 43.5in^2 cross sectional area of the line (for e.g. 7.25in x 6in)
Driver-centre 12.5in down from the internal top. Vent centre 32in down from the internal top.
Old 17th October 2008, 07:46 PM   #8
MJK is offline MJK  United States
Default Re: Other options
HERESEY! A least you did not recommend a SS amp.
Old 17th October 2008, 08:47 PM   #9
Did someone say SS with Lowthers?
First Watt at RMAF
I really enjoyed it. So did a large number of people who swore by tubes until then.
HERESEY!
Well, you don't make progress by sticking you head in the sand. So a little Heresey is good once in a while. Just as long as you don't get carried away and try to put a Lowther in something with a vent. (hey, I can have my fun too!)
Jon Ver Halen
Lowther-America
Old 17th October 2008, 09:05 PM   #10
Bob Brines's Avatar
And powered by a T-Amp!
Bob
cabinet for a lowther ex4 mjkempton Full Range 12 23rd September 2007 09:31 AM
Best cabinet design for ten thumbed lowther EX3 owner!? please klykx Full Range 11 23rd November 2006 08:04 AM
Lowther GB. steenoe Pass Labs 15 20th January 2006 06:20 PM
which cabinet: Lowther or Fostex Wardsweb Multi-Way 4 8th August 2003 03:27 AM
Page generated in 0.10635 seconds (78.49% PHP - 21.51% MySQL) with 11 queries
