Im going to pick up some boxes for a sealed bi-pole floorstander using 2x FE127E's per box. I have just had a quick look at the drivers which arrived yesterday and noticed they use a slim, spade-like, connection to the voice coil. I dont have any lugs here that would fit them, what do you guys recommend? im not sure if soldering directly the wires to the drivers is a good idea incase they get heat damaged? I was thinking the lugs would be good as the drivers can be easily removed if needed. Thanks for your time! Scribble |
#2 |
If you want the best possible connection, cold-weld / crimp them. Solder comes next. Fewer detachable / mediocre quality connections there are the better.
#3 |
You're in WA so there could be an Altronics handy. Have a look at the spade connector H1981A as is 2.8mm. Make sure you use a good crimping tool for connection onto the cable.
I don't have my FE127E any more so I can't check the exact size but you can open or close the spade connector to suit. I've used 100's of these on scores of speakers and never had an issue with them.
No longer DIY active |
#4 |
Yes, there's an Altronics on Roe Street, Perth, next door to the Metro night club.
#5 |
Thanks everyone!
I will go pick up some crimps if they have some in. |
| WTB Fostex FE127E | john65b | Swap Meet | 0 | 30th November 2008 05:35 PM |
| Box for the FE127e | despotic931 | Full Range | 18 | 11th November 2008 12:46 AM |
| Cables, Terminations and Plugs ! | EdT | Multi-Way | 15 | 20th December 2006 09:22 PM |
| working with the Fe127e | Roemhild | Full Range | 17 | 20th May 2006 07:41 PM |
| FE127E, Can I use this cabinet for them? | mbcy | Full Range | 7 | 13th February 2006 09:15 PM |
| Page generated in 0.08662 seconds (76.66% PHP - 23.34% MySQL) with 10 queries |
