Old 15th October 2008, 01:57 AM   #1
Cloth Ears's Avatar
Default Peak co-axials
I was wondering if there is a magical place where I can learn about Peak drivers. I picked up 4 of these co-axials (OK, not strictly fullrange) from the 'bay recently and there seems to be a decided lack of history on the Web about drivers or speakers from this maker. The baskets look the same as a lot of Japanese drivers from this era (I'm assuming 70's-80's).
Front:
Back:
I'll play with them anyway, but I'd like to know who Peak were and where they went...
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 15th October 2008, 02:11 AM   #2
frugal-phile(tm)
planet10's Avatar
Try searching for coral 6CX-1
I've had a single similar 8" thru here
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th October 2008, 07:16 AM   #3
Cloth Ears's Avatar
Thanks as usual, Dave.
I'll have to try at home - work doesn't let me in to those sites...
I haven't received them yet, so I'm not sure whether they need a crossover or not. From the pictures, it looks like they only have the one pair of inputs. If this is so, then tweeter must roll-off using the induction of the woofer's voice-coil - does that sound right? Or would the tweeter crossover be internal?
Maybe it will be obvious when I look at them.
Jont.
Old 15th October 2008, 07:40 AM   #4
frugal-phile(tm)
planet10's Avatar
When you take the can off it will be obvious...
dave
Old 15th October 2008, 08:21 AM   #5
Brisso57's Avatar
Peak 8CX-50's have actual XO's ... hidden behind the tweeter.
I suspect yours will also have something.
They look like Coral OEM's.
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 15th October 2008, 08:56 PM   #6
Cloth Ears's Avatar
Thanks guys.
I had a search for them but there wasn't much that hadn't been deleted (Yahoo auctions). But, as you say, when I take the back off there might be a whole different set of numbers to look for.
Can't wait...
Jont.
Old 18th October 2008, 10:57 PM   #7
DeKay is offline DeKay  United States
As mentioned they are re-branded Coral's.
The 8" version has a 2MF cap on the tweeter and that's it.
Never seen the 6", but the 8" is approx. 96dB-97dB @ 1 watt/1 meter and I'd guess the QTS to be @ .4 (or a bit less).
The paper surrounds will not take a lot of movement, so avoid high SPL's and/or boosting the lows/mids with EQ.
I like mine.
Old 18th October 2008, 11:05 PM   #8
Cloth Ears's Avatar
Much appreciated, Mr DeKay (or is your moniker a play on words? )!
Jont.
Old 19th October 2008, 04:32 AM   #9
You are welcome.
My moniker is based upon my first/last intitials, which has also been a nickname (pronounced DeKay for "DK) much of my life by various people.
Seemed like a good choice @ the time (latest 1900's:-) when I was registering @ few WWW forums.
I'm DeKay @AA & A'Gon as well.
Old 19th October 2008, 09:45 AM   #10
Cloth Ears's Avatar
Originally posted by DeKay
You are welcome.
Same, CE on various other sites (AK, MAC, Stereonet, Head-fi, Single Driver, ESP) just to be consistant. I'll be interested to see how they sound. I figure a couple of pairs of 'computer speakers' in sealed boxes (plus a 'subby' if necessary). would be what I'm looking for. If they're better than that, then... we'll see.
Jont.
Peak (or Coral) 8CX-50 sunnycue Full Range 35 5th July 2011 06:53 PM
200V peak to peak @25MHz ketan Parts 1 8th June 2008 03:21 AM
116 db peak db how loud is that 8cube Multi-Way 21 8th November 2007 06:45 AM
Pre Outs and peak-to-peak ? CheekyMonkeyVZi Car Audio 7 12th December 2006 08:30 AM
a peak at a TDA7293 amp quekky Chip Amps 17 8th February 2004 11:37 PM
Page generated in 0.09728 seconds (80.69% PHP - 19.31% MySQL) with 10 queries
