Old 14th October 2008, 11:46 PM   #1
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Default Fostex 208ESigma with ribbon..
I've heard it said before by some that the best overall bang for the buck from Fostex is the 208 with a tweeter.. Any thoughts on mating it with the Fostex ribbon tweet? ...
http://www.madisound.com/catalog/pro...roducts_id=275
http://www.madisound.com/catalog/pro...roducts_id=289
Dave
Old 14th October 2008, 11:55 PM   #2
DaveCan's Avatar
Also this one looks interesting from Hi Vi https://www.solen.ca/pdf/hivi/rt2ha.pdf
Mod's, although this is a 2 way system, I'm only after the Full Range mentality minded folk's idea's from this forum so hoping it can stay
Dave
Old 15th October 2008, 01:58 AM   #3
frugal-phile(tm)
planet10's Avatar
Default Re: Fostex 208ESigma with ribbon..
Fostex ribbon not efficient enuff to keep up with 208.
Basszilla uses a ribbon with FE208 but i'd think one of the Fostex horns would be a better match.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th October 2008, 02:00 AM   #4
frugal-phile(tm)
planet10's Avatar
Hi Vi
also not efficient enuff....
neither the HiVi or the Fostex are true ribbons, they are electrodunamic planars
dave
Old 15th October 2008, 04:28 AM   #5
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Basszilla uses an Aurum Cantus 2si true ribbon
Sounds good, it is efficient enough.
Probably the more expensive Fostex horn tweeters are good, but the cheap FT17 can't compete with the AC ribbon.
It would be worth getting the Bassilla Platinum
plans as they do include the crossover for hooking the two together.
The Basszilla is by Dick Olsher:
http://www.blackdahlia.com/html/tip_43.html
Old 15th October 2008, 05:53 AM   #6
DaveCan's Avatar
Thanks guys for the info, I'll look into that link.. Dave
Old 15th October 2008, 11:11 AM   #7
OzMikeH is offline OzMikeH  Australia
Here's a real ribbon that looks affordable.
A Fountek.
http://www.bmm-electronics.com/Produ...roduct_ID=6995
Help some guys with funny hair bang two rocks together really hard.
http://athome.web.cern.ch/athome/LHCathome/whatis.html
Old 15th October 2008, 02:53 PM   #8
DaveCan's Avatar
That one looks good also thanks OzMike...
I wonder why on the Basszilla the drivers are centered instead of offset on the baffle like others seem to do..?
Has anyone tried to mod the 208 with a wizzer and phase plug to bring the highs up ? Dave
Old 15th October 2008, 04:29 PM   #9
chrisb is offline chrisb  Canada
my $.02 (Cdn ) :
The Sigma is a highly evolved series - on the 108 through 208, the center is far more than a simple dust cap, and I can imagine that the only excuse to remove it would be severe physical damage (such as visited by inquisitive toddlers).
We have had occasion to install phase plugs on FE108E Sigmas with such damage, but I wouldn't suggest performing this mod to an intact pair of any model of this series.
I would sincerely doubt that a whizzer could be easily attached to the profiled main cone, or that it would improve the performance.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 15th October 2008, 04:45 PM   #10
DaveCan's Avatar
Good points Chris, I guess as usual I'm just thinking out loud I got to thinking that maybe if something could be done mod wise to bring the highs up on the 208, it could end up to be one of those 'sleeper' drivers that usually get overlooked but could kick some serious sound..
Dave
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
Fostex Ribbon RZ-2000 lpd Multi-Way 0 6th August 2008 11:51 PM
Fostex 3"-5" FR or ribbon? SemperFi Full Range 10 7th October 2007 04:30 PM
Ribbon Super Tweeter.. Visaton, Fostex, Aurum Cantus etc? tubenut Planars & Exotics 3 31st December 2005 05:14 PM
Fostex 206E/103E + Raven R-1 Ribbon + Dual 12" Yamaha Neodynium Open Baffle Speakers Steve M Multi-Way 4 28th July 2004 02:19 AM
Page generated in 0.10173 seconds (81.77% PHP - 18.23% MySQL) with 10 queries
