#51 |
could you also post the cone excursion? and up the power in the sim to see when it hits Xmax?
#52 |
Alpair showing woofer displacement at 50W. Xmax is rated at 8.5mm approximately.
#53 |
Jordan showing woofer displacement at 50W. Xmax is rated at 9.0mm approximately.
#54 |
Could this be a contender for a 2-way with sdx7 or should one stick with fr125s or alpair 5? I'd like to update my FR125s bipoles to something a bit more powerfull and with more "kick" in the 100-500 hz area.
#55 |
This was actually going to be my two way active cross over setup, the sub beaing a Scan Speak 8656 Carbon fibre cone. Was going to choose a XO at around 100 Hz 3-order, and a simple high pass at around 100 Hz as well for the Jordan or Alpair. Since the cabinets are simple, I might make two sets, and when I get the spare cash (big hit after Christmas) put in the pair A10 and then I can do almost a double blind test.
My idea, turn off the sub late at night for more quiet and intimate listening (I have a baby), and then have the full rig on during the day for full listening. Going to power the Jordan/Alpair with a low power 1-2W tube amp (small listening room), and a LM3886 chipamp for the sub. |
#56 |
I'm planning to mate the alpair 5 with the 10's bass driver, and seriously considering using pushpull 2a3 tubes with 15 watts.
mark is recommending 40-50 watts amp to drive the alpairs, he pointed kt88 or el34 tubes, although he's using vintage 2a3 with good results. im waiting for the right time to do this, since im terribly busy this past months. but hopefully on february will finish the alpairs its nice to see this driver gaining interest from alot of folks cheers |
#57 |
Im burning in my Alpair 10 FR.s on the livingroom floor, and on a comfortable spl level the meters on my amp show power peaks of about 1W. The floor probably ads gain, but what im saying is they dont need huge ammounts of watts.
#58 |
Hey all you guys who have tried the alpair. How do you find the sound so far? Thinking of getting the alpair 6
Oon |
#59 |
Alpair6 is the best 3" I've heard *), I can definitively recommend it. for moderate sound levels in not too large a room, also the bass is good. (I've tried them in the Needle (a ML-TQWT))
*) yes, it is also the most expensive 3" that I've heard, so no free lunch also here unfourtunately |
#60 |
Could you kindly post some details (in a new thread) ?
Most obliged, Patrick |
| Alpair 6 Bass Reflex Bookshelf | EUVL | Full Range | 61 | 7th October 2010 09:29 AM |
| Alpair 7 - out of the bag | markaudio | Full Range | 16 | 27th November 2009 01:30 PM |
| Alpair 12 - also out of the bag | markaudio | Full Range | 23 | 23rd November 2009 04:48 AM |
| alpair 10 box width ? | norman bates | Full Range | 9 | 15th May 2009 04:54 AM |
| Can anyone help TL or ML-TL for Alpair 10 | _henry_ | Full Range | 3 | 31st December 2008 07:31 AM |
| Page generated in 0.11193 seconds (74.18% PHP - 25.82% MySQL) with 11 queries |
