Old 6th October 2008, 03:04 PM   #1
Default aiko build
I am currently building a pair of Aikos with a fe108e driver. I was just wondering if any stuffing is reccomended/required before I glue them up. Any input on the type of stuffing material and stuffing placement would be great.
Thanks,
Chris
Old 6th October 2008, 03:37 PM   #2
Scottmoose's Avatar
None before you glue them. You can play with some damping in the low pass chamber to suit your own requirements afterwards.
Old 6th October 2008, 06:24 PM   #3
chrisb is offline chrisb  Canada
Default Re: aiko build
Thanks,
Chris
have your plans considered a Supra-baffle of any type?
I built a pair of Aikos a year or so back ( originally for the Lyeco , but they were embarrassed by the FE108E Sigma), and planted on an elliptical SB.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 6th October 2008, 06:58 PM   #4
Thanks, Scott. I am using the atlternate deflector (not the 'stepped') which leaves a chamber at the top and bottom corners. Should that area be filled to prevent any cabinet resonance?
Thanks,
Chris
Old 6th October 2008, 07:00 PM   #5
frugal-phile(tm)
planet10's Avatar
Been a while since i've been inside those... i think i put a bit of damping in the ends of the air cavity.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th October 2008, 07:05 PM   #6
Thanks,
Chris
let me answer for Scott (I should say on behalf of ) - I'd definitely fill the lower void with heavy ballast (i.e. sand / lead shot), and the top with perhaps with kitty litter. (without a wide base plate these will be very tippy if the top is filled with heavy ballast as well)
Old 6th October 2008, 09:45 PM   #7
Chrisb....the round 'baffle' on the original aiko plans...would that be considered a Supra Baffle?
Old 6th October 2008, 09:53 PM   #8
frugal-phile(tm)
planet10's Avatar
yes
Old 6th October 2008, 10:04 PM   #9
The "golden ratio" ellipse was just more aesthetically appealing, compared to the square SBs on Frugelhorns, etc.
I'd mocked up a round one and it just didn't seem to synergize with the aspect ratio of the Aiko cabinet.
Old 7th October 2008, 02:07 PM   #10
Planet10 and Chrisb....yes, I am using the round baffle from the original Aiko plans. I agree that the round baffle and the tall, thin cabinet looks odd at first...I hope it will grow on me. I'll post some photos when I get further on with the build. Thanks for all the advise!
Chris
Aiko owners, some suggestions please. 901Fixer Full Range 61 19th March 2009 07:52 AM
Page generated in 0.09281 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
