Old 24th September 2008, 03:36 PM   #1
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Default Subwoofers For Madison/Sachiko Speaker
As some of you here already know I've obtained a pair of CarderSound Madisons ---{CarderSound's version of the Sachiko for those who cannot DIY}--- and I'm absolutely hooked on their presentation of music. I have included a photo of my complete system taken from where I sit to listen, in case that helps.
I don't wish to debate whether or not Single Fullrange Speakers are really fullrange or not. I fully well understand & realise they don't cover 20Hz-20Khz ---{although mine are doing a quite respectable job from 30-35Hz-16-18Khzl}--- so yes they aren't really full range but, rather extremely wide range drivers!
That said, I don't feel any need at this time for any treble extention. I should explain that I usually ---{perhaps 90% of the time}--- listen to Smooth Jazz & Jazzy New Age music however, every now and then my desire for YES, Marillion, Genesis, Magnum, Shooting Star, Kansas etc. takes hold of me and when it does I find I wouldn't mind the extra foundation a subwoofer would add to the music.
So with that thought in mind I'm looking for recommendations a subwoofer that will match the speed, coherency, harmonic/tonal correctness and dynamics of the Madison/Sachiko design, while being efficient 96dB and up if possible, and capable of truly filling in from 50-100Hz and below in a manner that doesn't detract from what I'm already hearing. I don't care if your suggetion is DIY ---{actually I'm a bit surprised there isn't a DIY subwoofer on the Frugal-Horn site}--- kit or a manufactuered subwoofer provided it honestly meets my requirements. I realise I've asked about subwoofers before but, I haven't yet found or heard what I'm looking for. I would greatly appreciate any & all sincerely helpful responses.
Thetubeguy1954
Rational Subjectivism. It's An Acquired Taste!
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
Old 24th September 2008, 04:07 PM   #2
Godzilla's Avatar
The speakers look really nice. I have a pair of BIBs using Fostex 165k drivers and use a sub. I think you will need a 4 to 8 cubic foot subwoofer using a 15 inch driver to match the output and depth you want. Personally, i would build the sub myself.
Old 24th September 2008, 04:09 PM   #3
Scottmoose's Avatar
I remember you asking this before, and my answer hasn't changed: how about Jeff (nee CarderSound's) own?
There is a sub. on the FH site actually. See Shadow.
Old 24th September 2008, 04:16 PM   #4
Godzilla's Avatar
Neat design Scott. I like the shape of the Shadow. Loooong vent... very cool.
Old 24th September 2008, 04:44 PM   #5
frugal-phile(tm)
planet10's Avatar
Interestingly the "other stuff" you mention don't likely have any bass below 40 Hz... so you are probably looking for more midbass punch. This kind of thing was exemplified when we installed a pair of FonkenWoofTLs under our Fonkens. Measured extension only goes down an extra 10 Hz or so, but with a HUGE increase in available impact (the improvements in the mid-top due to hi-passing the Fonkens didn't hurt either.
This is exactly what the Cardersound woofer with its push-push modified SDX7s does, it actually doesn't go a lot lower than the Madisons. What it does do that most subwoofers don't do that CS Morgan does is go up to 950 Hz which allows very good integration. Fortuitosly the SDX7 loves a sealed box, and with the XBL motor, means that it responds well to EQ, I have easily gotten 25 Hz measured in-room before any fall-off, The thing is that you need to get some serious cone-area if you want to play ay significant levels. Time to look at multiplies then. We are just embarking on a pair of woofers that will have 4 SDX7 per side -- ideally this many fit into 2-3 ft^3 per side.
Getting that last little bit, or going infrasonic, with something that integrates is a challenge. When we finish playing with the SDX7 we'll be starting to play with some of the larger XBL woofers, likely the SDX10 to start.
Getting something 96 dB efficient, going low, and keeping the box smaller than a walk-in fridge is also a challenge, One of the oft overlooked issues is getting a box that big that doesn't act as an uncontrolled passive radiator (this is where IB using another room or cavity in your house as a box comes in).
You'll have to actively amplify the woofer anyway so this is really a situation where one can just throw power at the problem.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th September 2008, 04:55 PM   #6
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
It looks like you have corners there behind the Sachiko's, why not build a couple of 8" driver BIB's and use them as subs? I bet they'd match pretty well...
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 24th September 2008, 06:00 PM   #7
chrisb is offline chrisb  Canada
A BIB sub would be large enough to be impractical for a lot of rooms - and as the Madison/Sachiko aren't tiny to start with, this could well be one of the them.
OTOH, as Dave alludes, provided you have the power to through at them, multiples of the SDX7 are quite stunning, and can be crafted in pretty small boxes - particularly if the amps are outboard.
IMHO, a system like the Madisons and any well matched "sub" deserve better than the XO built into any plate amp I've yet heard.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 24th September 2008, 06:43 PM   #8
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Maybe the SDX10 would be a better choice than running so many SDX7"s? At least the 10 has some paper in the cone mix rather than just carbon fiber... Dave
Old 24th September 2008, 07:22 PM   #9
Hello All!
Thanks for all the input and please keep it coming. I'd like to address everyone seperately...
Thanks for the affirmation Godzilla! I love the way the Madisons look in Rosewood. Their looks are surpassed only by their sound! I could never go back to a multi-way, crossovered design again. I'm hooked on the way these types of speakers present music.
Scott yes I know you responded before and I want you to know I really appreciate all your input. If it wasn't for you & your work I wouldn't own Madisons! Remember I specifically stated ---{ I realise I've asked about subwoofers before but, I haven't yet found or heard what I'm looking for?}--- Jeff Carder does incredible work and I highly recommend his work and his customer service. That said the Morgan just didn't grab me.
I was hoping for something, somewhat similar to the Madisons in shape/size but, designed with the idea of being a subwoofer. I checked the Frugal-Horn site but cannot seem to find the Shadow you spoke of. Perhaps you could give me a link to it?
Dave aka Planet 10 I believe your suggestion of getting some serious cone-area, via multiples of drivers so I can play at significant levels is more of what I'd like! If you're embarking on a pair of subwoofers that will have 4 SDX7 per side, this is perhaps what I should wait for, unless of course you guys come up with an enclosure similar to the Madisons in size but designed to be and act as a subwoofer that I like better!
BHD Your suggestion is a lot more in line of what I've actually been looking for. For me visual appeal is an important factor. Obviously it's NEVER before sonics but, there's absolutely no reason we cannot have both especially in the DIY community. I love the idea of a couple of 8" drivers in BIB's and using them as subs but, the enclosure would have to be optimized for that usage no? So as I don't know if the BIB's as is are optimized to be used as subs I'd need more info before proceeding in that direction.
chrisb My room is a dedicated audio room. When we purchased our home my wife and I agreed she could decorate all rooms in the house ---{except for the audio room}--- anyway she wanted to but, this room is mine and I have free reign to do what I will as I choose to. So there's no issue with the BIB's being to large! IN fact as I've mentioned a few times already I'd like the subs to be close to the size of the Madison/Sachiko as possible. Fact is "IF" I could have afforded these http://tinyurl.com/4qtmvp I would have bought them, placed them in the corners of my room, removed the mid & treble drivers and used these as subwoofers!
Thanks Everyone!
Thetubeguy1954
Old 24th September 2008, 08:22 PM   #10
Default Shadow
I heard from GM, who provided me with a link to the Shadow. I had tried finding the Shadow before on the Frugal-Horn site but, I couldn't locate it ---{thanks again for the link to it GM}--- now that I've actually see the Shadow, if I can have a pair of stacked Shadows built as a single enclosure, with a mouth on the top and bottom to match the Madisons in appearance, I believe this would be exactly what I've been looking for! Plus the addition of 4 more woofers ---{as I'd want a pair of stacked Shadows built}--- would add to their dynamic capabilities and power handling.
Now I have to contact Jeff @ CarderSound and ask what a pair of these "stacked" single enclosure Shadows done in Rosewood ---{so they match the Madisons}--- would cost me! This is the closest thing I've seen to what I've been imagining as my ideal subwoofer. Thanks very, very much to everyone who suggested the Shadow!
Thetubeguy1954
Madison Executioner 21', free alain_online Swap Meet 0 26th February 2009 07:38 AM
Madison Executioner X21 (Magnetar?) BHTX Multi-Way 7 31st December 2007 11:23 AM
WTB: 4+ Madison Executioner X21 woofers BHTX Swap Meet 0 30th December 2007 10:51 AM
Madison's Nht 10" Sub Kit DAVE CC Subwoofers 6 28th June 2007 12:10 PM
JBL L300's for sale - Madison,WI RADIOLEE Swap Meet 6 8th September 2003 03:10 PM
Page generated in 0.12965 seconds (82.49% PHP - 17.51% MySQL) with 11 queries
