I have been busy the past couple of months designing, building, and testing a new two way dipole speaker system. The resulting speaker has an efficiency of 88 dB/W/m and covers the full spectrum from 20 Hz to 20 kHz. You can find pictures and the documentation of the design on the Projects page of my web site.
#2 |
Hi Martin,
Apart the obvious compliments, particullary for excellent calculated Vs measured data, I have two question: 1) How is imaging with such large baffle? 2) How bad are the vibes ?Excuse for my rude english, I found your work always accurate and scientific. Cheers, Paolo |
#3 | |
Imaging is very good, as good as any of the other systems that have been in my room. I assume you are asking about cabinet vibes. To be honest I have not spent much time investigating cabinet vibes. In the future I am going to add mass using a large piece of stone iwhich should be a step in the right direction. But I am not sure it is required. |
#4 |
Thanks Martin,
Paolo |
#5 |
Hi Martin
I like your work esp. correlating theory with measurements. I quote you from your project paper "The use of an active crossover really makes the system work. Levels and crossover points can be adjusted to optimize performance. Crossing low maintains the full range driver sound while removing the demand to produce bass from the Jordan. The system comes together really well, deep dynamic bass and clear crisp response from approximately 20 Hz to 20 kHz. But be warned, at 88 dB/W/m it does take some power to make them really sing their best. At the end of an evening of enjoyable listening at decent volume levels, my amps are warm." 1) How do you choose the crossover frequency and order of the active filters? I realize this is partly based on the excursion tradeoffs of the fullrange driver and the want to cross low. But there is alot more that comes to play here... yes? 2) Can you discuss the highpass boost to the H frame woofer in more detail? 3) Are you going to publish circuitry details for 1) & 2) ?
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#6 | |
2) I just applied a 2.5 dB boost, I tried other values to see what sounded most balanced and it came down to between 1.5, 2.0, and 2.5 dB settings. I settled on the 2.5 dB value for now. 3) The only thing I build are the speakers. The amps and crossovers are all off the shelf purchases. I have no interest in electronics design and construction. |
#7 |
Another excellent and informative article. to address some points in this thread and the article : The c/o point selection principles are in the other articles. For all things active see http://www.linkwitzlab.com/ The sensitivity and gain adjustment indicates a bucketload of drivers would work in this design, if they are flat or passively EQ'd flat. The Tangband-W4-1337SA (with some form of treble disperser ?) springs to mind for 86dB/W, just reduce the bass gain a little. Regarding the need for or lack of a treble driver : Off axis response does matter and is perceived at the listening position by the ratio of reflected to direct sound, how much ? YMMV but off axis starts going off at around 3KHz. Adding a tweeter would bring in a lot more driver possibilities. The Tangband W5-704D + tweeter would certainly be cost effective. |
#8 |
Martin,
What is the excursion like on the goldwood in the h-baffle around resonance? Sean |
#9 |
Excellent article!
I prefer the JX92s to the Lowthers I have (DX2) But, the wife & kids don't agree so I am gonna take the Jordans to the office & re-set up the lowthers in OB |
#10 |
Active highpass so a 2-way active speaker
| Page generated in 0.12454 seconds (80.84% PHP - 19.16% MySQL) with 11 queries |
