Hello,
This is my first hifi DIY speaker build, and I was hoping someone more knowledgeable in this area could look over my cabinet calculations and provide feedback. I'd like to maximize the bass response as much as possible. Would someone who has access to a speaker simulation program calculate the frequency response of these speakers with a BIB cabinet? The MOTH BIB cabinet seems rather small as compared to the B20 dimensions. Size for me is not an issue. Any recommendations are greatly appreciated! Attached is the MOTH driver specifications, and below is the BIB cabinet dimensions. Thank you! -David
#2 |
Here's a picture of the driver.
-David |
#3 |
It will be smaller -you've a much lower Vas. I make basically the same size, give or take a whisker.
#4 |
Greets!
Well, you inputted Vas/Qts as 0.21 ft^3/0.67 when it should have been 0.7416/0.67 respectively, so it's much larger at >9 ft^3. Before going any farther though, you need to get them measured as the published specs aren't even in the same country as the measured specs I have, which will make it prohibitively large unless of course you don't mind anteing up for a couple of ~46 ft^3 cabs: Re= 11.2 ohms Le= 0.13mH Fs= 47.3Hz Qms= 9.6 Qes= 1.23 Qts= 1.09 Sd= 201 cm^2 Vas= 58.5 liters Cms= 1.03 mm/N Mms= 11 gramms Rms= 0.34 kg/s BxL= 5.42 N/A SPL= 91dB These specs in the 9+ ft^3 cab looks pretty bad, but you never can be sure till you build/audition one in-room, so as always YMMV: GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 | |
GM
#6 |
the specs say 21 'litters' .... not cu. ft.
therein the confusion I think |
#7 |
How so? He inputted 0.21, not 21..........
GM
#8 |
21 litres ~ 0.74 ft^3 not 0.21
Scott accepted the specs he had inputed. |
#9 |
GM & Hitsware, and all,
Thank you a TON for your help and thoughtful oversight. Below are the revised cabinet calculations using GM's measured values. I had read in other professional reviews of these drivers that the measurements were different than the published specs, but could not find any other values. This was helpful. Do these numbers look better? -David |
#10 |
You're welcome!
Unfortunately, you didn't. The 21 L Vas is the published spec that you converted incorrectly/whatever. The measured Vas spec I posted is 58.5 L, so convert this to ft^3 using the spreadsheet's built in converter. If you don't wind up with the 46+ ft^3 Vb with the new Vas I mentioned earlier, then try again. GM
| Moth 'Flutterbuster' TT psu | Sid and Coke | Analogue Source | 10 | 11th October 2010 08:49 PM |
| WTB: Moth Audio Cicada Drivers | recstar24 | Swap Meet | 2 | 17th November 2008 09:09 PM |
| Need new low profile caps for moth amp | August | Solid State | 4 | 9th February 2004 05:45 PM |
| Fostex FE207 vs. Moth Cicada | Kashmire | Full Range | 4 | 10th January 2004 04:45 AM |
| box volume for Moth Cicada? | trespasser_guy | Multi-Way | 1 | 18th June 2003 05:05 PM |
| Page generated in 0.10175 seconds (77.66% PHP - 22.34% MySQL) with 11 queries |
