ML TL or Half Chang for AN s8 ?
Old 17th September 2008, 10:10 AM   #1
aroS3 is offline aroS3  Greece
Send a message via MSN to aroS3
Question ML TL or Half Chang for AN s8 ?
Hi, to you all DIY mates,
I took recently in hands a pair of Audio Nirvana super 8" CF for my first DIY fullrange speaker.
I'm very anxious to have them in an appropriate and not so complex enclosure and enter the Fullrange world.
I 'd like all the experts here to advice me which of the two enclosures (MLTL or Half Chang) could be more prominent regarding efficiency and bass output.
Thanks in advance,
Best regards,
George
Old 17th September 2008, 10:52 AM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Hmm. Assuming the published specs. are accurate (dubious) the AN isn't ideal for this kind of load without some form of correction as it's a very low Q unit. However, there are ways around that.
HC is a bit small for it. Here's an MLTL though: 54in tall, 82.5in^2 CSA, 3in diameter x 1in long vent 2in up from the base. Driver-centre (Zdriver) 19.125in down from the top. Line top, back & one sidewall with 1in acoustic fiberglass or similar & adjust to taste from there. Dimensions all internal. FR plot assumes 5ohms of series resistance added; depending on where they're positioned & what your amplifier is, you might be able to get away with less or none. There are plenty of other MLTL options / sizes etc too of course.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 17th September 2008, 11:33 AM   #3
Thanks a lot for the calc Scott. Always helpful for the team here.
Only DIY tube amps from 2 to 20 Watts are available for them. Not a single SS amp for the moment.
ML TL or Half Chang for AN s8 ?Hide this!Advertise here!
Half Chang or Suzy Chang with Subwoofer? tripathdude Full Range 2 15th December 2008 04:47 PM
Half Chang or BIB? tripathdude Full Range 2 30th November 2008 02:32 AM
Half Chang to fit my need's ? lykkedk Full Range 32 14th January 2008 04:24 PM
