Hi all,
1st post here. I have been offered a pair of NIB Hemp CO8Vs. I thought they were able to be used without a crossover but they aren't. I am still interested in trying these out though. I do have a CNC machine so cabinet building is not a problem. I was thinking about a Transmission Line (similar to these) cab using Trans-Laminated ply. Cabinet volume of approx 25-30lts. Would this be the correct choice for these drivers? Many thanks. |
#2 |
Hi Spacies,
Welcome to the club Without knowing more info about the driver (parameters like fs, Qts, Qes,Vas, etc. and a plan for the transmission line it hard to tell. Regards, Eric |
#3 |
http://www.hempacoustics.com/products.php
http://www.hempacoustics.com/CO8V_-_...heet_ready.pdf 25-30 L implies a ~T/S max flat vented or old tech TL alignment which for the latter equates to anemic bass and excessive loss of efficiency due to baffle step compensation (BSC) if either not corner loaded and/or a high Q driver and/or a 'sub' is used. Plus, due to a relatively high Fs, low Vas, then if tuned to fill in the mid-bass there's no bass of consequence, so another type of cab design may be desirable. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 |
Thanks,
The specs are here: http://www.hempacoustics.com/CO8V_-_...heet_ready.pdf I can do the cabinets easily enough but when it comes to specs, I need to study more. |
#5 |
Thanks GM.
As posted above (once moderator clears) the cabinet type isn't a problem. I would like some advice on the cabinet style best suited for them. Cabinet type, volume etc. I am very excited about starting to use full range drivers having done a MTM. I would prefer no crossover but the Hemps just have an appeal and are waiting for some music to be played through them. |
#6 | |
frugal-phile(tm)
You can actually touch these drivers? Actually finding a pair of these drivers is a feat. I wouldn't trust the factory specs BTW. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Just paid for these drivers.
So in a couple of days I will be able to touch them. The price was too good to turn down. |
#8 |
Well they just arrived.
So, who has a pair of these running? Any info to share? Thanks. |
#9 |
Pics and an assessment of build quality would be nice. Measurements would be even better.
#10 |
I have a pair of co15v laying araound.
Not sure what to do with those either
| Hemp Coaxial | inrank | Multi-Way | 83 | 27th July 2011 08:28 AM |
| Hemp FR8 vs Hemp FR8C - Which One? | Estes | Full Range | 16 | 4th May 2009 07:42 AM |
| HEMP FR810hq | one1speed | Full Range | 10 | 4th April 2006 07:11 PM |
| Page generated in 0.08693 seconds (86.29% PHP - 13.71% MySQL) with 11 queries |
