Have been pondering what if any ill effects arise from having the panel directly behind the drive unit in a BiB so close to the driver.
Would it be possible to make a chamber behind the driver to reduce the intensity of reflections with the taper exiting above and below without stuffing up the performance? (assuming that you put a corresponding hump in the rear of the cabinet if you're using a folded taper so that the cross section remains constant. Is this effectively any different to placing a spacer panel on the front of the cabinet to move the drive unit forward anyhow, or does the whole BiB thing rely on a smooth taper in the line with as few interruptions as possible? |
#2 |
The latter, if it's to remain a BIB anyway. It's a pipe horn. Generally, a little damping is placed behind the driver anyway, which prevents any issues with early reflections. Nothing to stop you making a version with a low pass filter chamber of course.
| Page generated in 0.05900 seconds (64.54% PHP - 35.46% MySQL) with 9 queries |
