Diffuser in front of a room corner:
#2 |
Rear side of absorber/diffuser:
#3 |
FR without absorber/diffuser:
#4 |
FR with absorber/diffuser:
#5 |
The material had cost me about 12 Euros per element.
Some measurement conditions: The subwoofer belonging to the "Dipol 08" OB was switched off. A single speaker was placed in a way, that the rear lobe of the dipole was aiming directly at the corner. PLEASE NOTE: This is a demo setting for the absorber/diffuser, not a proper placement of the "Dipol 08" OB-Speaker. 2 curved absorber elements 100cm X 60cm were stacked ontop of each other and placed in front of the corner. Distance of OB to the corner approx 1.6 m. Distance of microphone approx. 60cm to the front of the baffle. Microphone approx. 40cm from the bottom. Non directive microphone. FR measured using impulse response, each measurement averaged over 10 impulses. Results are well reproducible. Remarks: My room has not very much furniture, there was too much reverberation and unwanted room gain in the low bass to mid bass region. The absorbers were designed built to adress that problem. Sonically it is a great improvement. Bass is more tight. Maybe as a consequence of that the whole midrange sounds more open. To improve a given audio setup, money cannot be invested better, than into adressing the listening room's acoustical problems ... I know, i am not the only one saying that ... I have built and setup 4 elements up to now. Kind regards |
#6 |
Material used is 3mm hardboard.
Holes are 5mm in diameter on a grid of 15mm. I used a version coated white at one side. This is a material very common in every german hardware market. At the long edges there is 23mm X 23mm square timber attached with screws to the hardbord. To get the thing curved i stretched 2-3 cords through some wholes in the timber ... thats it. Cheers |
#7 |
To get the same amount of deep bass subjectively,
i had to increase the level of the subwoofer significantly after placing the elements. Maybe 6 dB, don't know exactly. If the low bass extension of your system is based on room gain - like in some OB designs or small horns - you will have to compensate for the reduced room gain. In a heavily furnitured room, i think the effect will not be that dramatical. But in a sparely furnitured room with "naked edges" and walls the elements serve very well as an "acoustical emergency break" in the bass region. I called the design "cheaptrap" unless someone has a better suggestion Cheers |
#8 |
Cool design. Very creative!
double complete rainbow all the way!! |
| Diffuser on NS-1000 | phillfyspoon | Multi-Way | 9 | 28th May 2010 08:27 AM |
| skyline diffuser calculation | rabarbarusa | Everything Else | 0 | 6th October 2008 09:45 PM |
| Cheap Absorber/Diffuser | LineArray | Full Range | 6 | 16th August 2008 12:19 AM |
| Aeropanel acoustic absorber | ralphs99 | Multi-Way | 46 | 18th September 2006 12:50 AM |
| Helmholtz bass absorber, where to place? | banana | Multi-Way | 3 | 26th July 2006 04:13 PM |
| Page generated in 0.09971 seconds (77.36% PHP - 22.64% MySQL) with 11 queries |
