Old 12th August 2008, 10:21 AM   #1
Lostcause's Avatar
Unhappy WAF issues
Hi Guy's, after redecorating and 'rejigging' the room I need to look at rehousing my FE207E's in something more..... 'discrete'? (currently MLTL's)
I was thinking of building them into the dresser/cupboard in sealed cabs.... I've read that as low as 10.2L can be good for low level listening?
I can then put a SUB in the bottom of the unit and even put my FT17H tweets firing out of the top...
All hidden away nicely and good for low level listening over a meal and a bottle or two...
Any advice or experiance would be greatly appreciated on this issue
Old 12th August 2008, 11:20 AM   #2
Brisso57's Avatar
What do the current cabs look like? Post a picture.
Perhaps they can be dressed up a little.
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 12th August 2008, 11:51 AM   #3
Lostcause's Avatar
That has been discussed but they are rather big for the room and I can't put them in the corners were they are now. No pictures to hand at the mo..
I've had my way for nearly two years now so it's time for a change ‘she’ reckons.
I’ll keep the cabs in the loft for a rainy day……
It might be fun to get this arrangement working anyway, they would be at head height when seated….
Old 12th August 2008, 02:39 PM   #4
Rehouse the wife? Or is that a bit too extreme
Old 12th August 2008, 03:19 PM   #5
Lostcause's Avatar
Temping.........
Old 12th August 2008, 03:58 PM   #6
Lostcause's Avatar
I found a thread on another forum talking about a similar situation using them as a home cinema system. 10.2L cabs with the sub crossed in at about 80hz.
It sounds like it may just work especially at the volumes I normally get to listen at
One thing I am worried about is the beaming of these drivers, currently they are toed in quite dramatically......
Old 12th August 2008, 04:48 PM   #7
GM is offline GM  United States
GM's Avatar
Right, while you're moving in the right direction of sub/sat with the 206E IMO, any driver with a rising response will need a contour shaping network if mounted perpendicular to the listening position to flatten its response, necessitating a tweeter to get an acceptably wide/flat power response.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th August 2008, 05:32 PM   #8
Lostcause's Avatar
GM
..... and I have a couple of FT17H's sat on top of them at the moment so it sounds as if this could work... but I'm gonna need some help here if you dont mind chaps.... this really isn't something I know how to simulate
I do have them bi-amped with two T-amps at the moment as well.... it was easier when getting the balance just right.
This sub is going to be completely new ground for me as well, the only one I've ever switched in was off a computer setup and I only used it for very low frequencies..... once I got my amp/MLTL's sorted I didn't need it anymore.
Edit:
Hold the phone... I think was you who I was reading on another thread GM...?
Old 15th August 2008, 08:43 AM   #9
Lostcause's Avatar
OK I've been having thoughts about the beaming issue as the closest listening position will be about 1.5M away...
Should I go for ear level and put 'light bulb' phase plugs in there...... or should I go for above ear level? More like standing ear level?
Also, if anyone could recomend a suitable and cost effective sub driver/design it would be very much appreciated.
I am also wondering if I could actually disguise the whole thing within the cabinet? i.e build the unit around the existing cabs?.... Now that might work but the front baffle wouldn't be a flat face like it is now... would that matter too much?
Cheers
Old 15th August 2008, 04:06 PM   #10
GM's Avatar
Originally posted by Lostcause
Edit:
I post on a many threads, which are you referring to?
GM
NAD 216 issues Kamuy Solid State 28 17th December 2009 04:16 PM
IP issues GRollins The Lounge 25 10th July 2007 06:43 AM
CFB Issues Fuling Tubes / Valves 12 23rd August 2005 08:34 PM
Windows XP issues.. mikeks The Lounge 7 9th July 2005 11:29 PM
Page generated in 0.10460 seconds (87.42% PHP - 12.58% MySQL) with 11 queries
